I start the car and the lights out, drive a bit and it comes on and doesnt go back out.
The car has failed its yearly test on the fact the light wont go out. The mechanic got an auto electrician to have a look but he said he couldnt 'plug into the system' (im guessing the ABS ECU??) now the mechanic says the car should go to Toyota and that they will charge alot for labour and the car may need new ABS sensors at a cost of between "£50-200 each". Incase you didnt know £200 is $400 PER sensor
What should i do? Should i get a new auto electrician to have a look? Why couldnt the electrician 'plug into the system'??
Thanks
