Tranny Temp. Gauge install? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2007, 02:15 PM   #1 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
Is it necessary to drill a hole in the pan or is there a wire you can tap into?
Thanks =)
WhiteRabbit is offline   Reply With Quote
Old 05-14-2007, 02:28 PM   #2 (permalink)
View toyomoho's Photo Gallery
The trans does not have any temp sensors to tap into. Might be able to find a temp sender that can be spliced into the trans cooler return line.
Old 05-14-2007, 02:57 PM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
The only way to install the gauge sender in the pan would be to weld a bung into the side of the pan. If you just try to drill and do an RTV quick install, it'll leak. toyomoho has a good sugestion to find an in-line install kit. Question: Where would be the best place to install a temp gauge sender? Line out of tranny, return line, pan, torque converter, in order to get the best information on your trans temp? Why do you need a trans temp gauge in the first place?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-14-2007, 03:40 PM   #4 (permalink)
TN's furry friend
im just looking for gauges to fill my pod and was trying to see how easy this one would be
from the looks of it now, ill probably pass on it
but still good info to know i guess.
Old 05-14-2007, 03:54 PM   #5 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
the easiest gauges to install on the 5sfe IMO would be a/f, volts, oil pressure, and oil temp.
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 05-14-2007, 04:11 PM   #6 (permalink)
TN's furry friend
^what about water temp?
Old 05-14-2007, 05:20 PM   #7 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
lol..that's kind of ironic considering that the tranny temp gauge is the most important gauge for an automatic car....even the oil temp gauge isn't as important since it will also heat up your coolant and make the stock coolant gauge rise and let you know there's something wrong
and the tranny cooler sender unit can easily be spliced into the stock inlet/outlet hoses that go from your transmission to your stock tranny cooler located at the bottom of your radiator
you will just have to go to a plumbing shop and find fittings to fit your hoses and your sender unit, then use clamps
HaHa
Old 05-14-2007, 05:40 PM   #8 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
The return line from the cooler.
The only way to tap into the thin pans isn't to drill them, but hit them with a punch. That way the metal is folded intwards giving you surface area to tap to. The other way is to drill a hole & weld a bung on. Both would be hard to do on an A/T. The pans are very shallow.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 05-15-2007, 11:39 AM   #9 (permalink)
View 99Camry99's Photo Gallery
I would definitely NOT drill or make any hole in the tranny. It just increases the risk of something breaking or leaking. I have a trans temp gauge and I went to home depot, lowes, whatever your local hardware store is, and I bought some brass fittings. I made a "T" where the top of the "T" is in-line with the tranny hose and the bottom has the temp sensor. It works perfectly. I have an autometer gauge and it came with a sensor. If you folks want pics let me know. I'm at work but could post them later tonight.
99 Camry LE, Pioneer HU, Sirius, Boston Speakers, 2 12's, Tinted, CAI, K&N, Brembo Cross-Drilled, UD Pulley, Blue LED Underbody, Blue Wheel Well LED's, Blue, White, Amber LED Strobes, Corner Strobes, Autometer Gauges, Optima Yellow Top, “Big 3”, 1200w Inverter, Fog Machine & More... Ask
99Camry99 is offline   Reply With Quote
Old 05-15-2007, 11:56 AM   #10 (permalink)
TN's furry friend
^pics please
Old 05-15-2007, 11:58 AM   #11 (permalink)
you got it, I should be able to post by 6 assuming I get home without traffic.
Old 05-15-2007, 12:02 PM   #12 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
i would do it on the tranny line. get a "T" for it. its the easiest, safest way.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 05-15-2007, 04:36 PM   #13 (permalink)
That's the "T" I was talking about. In the first pic you can see the sensor on the top. The fluid runs from side to side. You could use pipe tape to seal it but I used the liquid form because it hardens.
The second pic shows it installed in the engine compartment with pipe clamps. I put it on the lineout because that way I know what the highest temperature is and it HAS to be cooler going back into the tranny.
The third pic shows my trans cooler. The fluid flow is: Tranny Out, Trans Temp Sensor, Stock cooler, Hayden cooler, Tranny in. There is definitely a difference. I can cruise on the highway and not have the tranny temp be over 120 degrees. Once the outside air temp goes above 60 degrees it doesn't work as well.
The reason I have the Hayden cooler after the stock cooler is because the fluid would warm up if it went into the Hayden cooler first then through the stock cooler last.
Stock operating temp is 156 degrees to 174 degrees. (give or take) To give you an idea.
Last pic is my Trans Temp Gauge! (Car was off and sitting for a while, so no temp) Hope that gives you some help.
Old 05-15-2007, 04:52 PM   #14 (permalink)
TN's furry friend
^lots of help, thanks alot!
what other gauges do you have btw? was thinking between the cobalt and cf series. trying to find a pic of how the carbon fiber ones look like lit up. cobalt sure looks good.
Old 05-15-2007, 05:02 PM   #15 (permalink)
So what is the optimum transmission oil operating temperature? Is 120F too cool?
http://www.digi-panel.com/digidevicesweb/trannyoil.htm
I don't understand the reason for a trans cooler on a street car that does not pull loads. Wouldn't you think Toyota engineered it right without an extra cooler? Installation of a temp sensor on a stock system would tell you how hot it actually runs.
Boost Gauge install write up. 05+ taco xrobber 2nd Generation (2005+) 15 07-12-2006 07:21 AM
temp gauge doesnt move 88Cam Camry & Solara Lounge 14 03-20-2006 01:50 PM
1993 Corolla/Prizm Temp gauge stays cold all the time dwikiz Archived Corolla threads 4 03-12-2006 12:49 PM
Broken Temp Gauge Sarstan237 Celica Forum 3 02-20-2005 02:14 PM
Coolant temp gauge messed up spills1969 Camry & Solara Lounge 2 02-15-2004 12:26 PM
