I currently own a 1996 Toyota Vienta (the 4cyl were called the camry & the vienta was the V6 in aus) Auto.
In australia we never got the 1mz-fe engine on the gen 3's we were left with the 3vz-fe.
Well, the problem started a few months back......Sometimes i will start my car, put it in drive and every once in a while we may feel a small jerk/thud.. this happens when we are stationary at the lights, moving very slowly...i think its only 1's gear this happens but once i shift from drive to neutral then back the problem seems to go away msot of the time.
Everytime the car thuds the revs drop very slightly and then return. Sometimes the thud is harder than usual and other times it is quite frequent.
The car has done only 160000kms and we have cleaned the fuel filter and serviced the tranny (flush, etc.) and given it is general service within the last 1000kms.
Im hoping we dont need a new transmission or something & hope its only a small problem.
Thudding reminds me of engine mounts .... worn, broken, loose. ... Not sure where they are located on the V6, but you might inspect/shake/shift around and see if anything is obviously wrong
When you say you feel a small jerk or thud, it sounds like maybe you are experiencing a rough downshift or even late downshift since you feel it when stationary. It may be in the transmission itself, or it may be a sticking throttle pressure cable, sticking shift solenoid, etc. Other things to have checked would be the TPS (Throttle position sensor) or the vehicle speed sensor in the transmission. Is the O/D light blinking at all? If the problem cannot be found, the next thing to do is a full trans diagnosis including road test, stall test, line pressure test.
well i dont think its to do with downshifting or upshifting..even if im slighly rolling forward 30 seconds later or have been sitting stationary for 10 minutes it still jerks at random times. i also noticed it jerks in reverse, neutral & drive...i dont know if this makes much difference.
Someone also told me it could be the transmission or engine mounts.. is this completely wrong or is this possible.
Well it seems 2 shift properly into drive, reverse etc..... it just randomly occurs while the car is running at a low speed or stationary until i stop the car
Well a few months later the problem is fixed... There was a crack in one of the spark plug leads which was causing a short. The mechanic replaced the leads, new spark plugs etc. now it is running like the day it left the production line.
Well thanks for all your feedback over the past months....
that's great that the problem was found and it was a relatively cheap fix. thanks heaps for letting us know. most people don't bother posting back with the final outcome.
I had a similar problem on my 92 Accord...except I was getting the jerking and stuff when I would step on the gas hard (more spark going through at WOT). Took me forever to find out what was causing it...but it ended up being a spark plug wire. There was a 'crack' in it that you could barely see, and the crack was down in the plug tube..so the spark was coming out of the wire and hitting the tube wall...instead of going to the spark plug.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
