Help--Stuck Steering Column - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2007, 02:56 PM   #1 (permalink)
View fcampbellcraven's Photo Gallery
Question Help--Stuck Steering Column
I just got a used 1996 Camry LE and can't start the car now. I can't turn the key over, and it's stuck in the "locked" position. I've tried all the old standby fixes, cranking hard on the wheel while attempting to turn the ignition key but I can't get anything to work. No manual came with the car and I've got one on order, but any help in the meantime would be much appreciated. I've searched this forum and haven't been able to come up with an answer.
fcampbellcraven is offline   Reply With Quote
Old 05-15-2007, 04:07 PM   #2 (permalink)
View keithy's Photo Gallery
set the transmission to "park" and try again?
keithy is offline   Reply With Quote
Old 05-15-2007, 05:43 PM   #3 (permalink)
If I'm not mistaken, you can turn the steering wheel, .... apply torque to it, and turn the key at the same time. It ought to unlock. No great effort required ... try it two or three times to get it to unlock. ... I think it's a security feature of some kind. You might have to have the battery connected ... not too sure about that, though.
Old 05-15-2007, 06:25 PM   #4 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
what i normally do is when i park my vehicle is after i stopped the engine, i remove the ignition key, and pull the steering wheel to left or right a little bit until i hear a click to lock the steering wheel in additional the club lock, next time when i start the engine, all i need to do is turn the steering wheel left or right while turning the ignition key to on.
bronzemaxell is offline   Reply With Quote
Old 05-15-2007, 07:06 PM   #5 (permalink)
View lenjack's Photo Gallery
Is there an unlock button in front of and to the left of the shift lever?
lenjack is offline   Reply With Quote
Old 05-15-2007, 07:34 PM   #6 (permalink)
.... I took a look at the 96 Camry steering wheel pdf. On page 12, there is something called the steering lock mechanism. If nothing else works, I would probably see what is involved in checking out that part.:
http://www.**********s.com/camry/sr.pdf
It may be that you can remove the lock mechanism without removing the steering column.
There is also a solenoid that is involved somehow. Be sure this part is functioning properly.
.... clean electrical connections ... use contact cleaner spray.
Is it possible that you have blown a fuse that would affect the lock mechanism operation?
I would check first ....
... Let us know what you find out.
Old 05-15-2007, 07:53 PM   #7 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Have you tried jacking up the front of the car to take the weight off the front tires, and then turning the wheel and turning the key?
uibalnme is offline   Reply With Quote
Curious about swapping steering wheels. Driver General Discussion 3 02-21-2007 03:00 PM
Steering knuckle and hub assembly abew330 Camry & Solara Lounge 0 02-07-2007 06:02 PM
Steering column wear? chrissr Camry & Solara Lounge 0 09-02-2005 07:48 PM
1989 Camry, 4dr Vandalized... Steering Column replace ? sdhartney 1st & 2nd Generation (1983–1986 & 1987-1991) 12 02-27-2004 06:16 AM
Road Noise and Feel through Steering Column camry dark gray Camry & Solara Lounge 1 02-07-2004 09:56 PM
