messed up dipstick?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2007, 08:26 PM   #1 (permalink)
Dragon877's Avatar
View Dragon877's Photo Gallery
hi guys i got a real big problems with my 94 camry...i cant seem to check my oil level cause my dipstick is all bent and weird.....it goes in and out of the hole fine but it never seems to read any oil level
i know i got plenty of oil cause i just got an oil change bout 1700 miles ago, and i added a full qt of oil less than a week ago, but my dipstick doesnt show any oil at all..is there anyway to fix it or anybody know where i can get a new dipstick?
Dragon877 is offline   Reply With Quote
Old 05-15-2007, 09:09 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
toyota dealership. i had to replace mine after i bent it. wasnt too expensive though.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 05-15-2007, 09:13 PM   #3 (permalink)
aussie_gen1's Avatar
View aussie_gen1's Photo Gallery
Well, if you want to be sure, you could replace the oil yourself with the correctly measured amount, and see if the dipstick works... or just replace it.
It's not unheard of for a 13 year old car to use oil.
Did you check the oil level after it was changed?
aussie_gen1 is offline   Reply With Quote
Old 05-16-2007, 12:40 AM   #4 (permalink)
Heat's Avatar
View Heat's Photo Gallery
Why did you add a full quart a week ago? And when you last had your oil changed, did you do it yourself or pay somebody to do it? If you did it yourself, how many quarts did you add?
Heat is offline   Reply With Quote
Old 05-16-2007, 01:00 AM   #5 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
overfilling your crank is just as bad as having it underfilled.
get a new dipstick...and pray that you havent been driving with an overfilled engine.
nodrogkam is offline   Reply With Quote
Old 05-16-2007, 03:19 PM   #6 (permalink)
Dragon877's Avatar
i had to drive down to philly so i added a qt...if i overfilled my crank wont the engine get completely messed up? i drove down to philly and back and everything's good
Old 05-16-2007, 03:32 PM   #7 (permalink)
Gameroom cash: $303055
If you know of someone who has a generation 3 Camry with your engine (I4 or V6), drive over to their car and ask to use their dipstick to check your oil. If the oil now registers on their dipstick, go to the dealer and get a new one or try a salvage yard. If it doesn't register and it looks the same as your dipstick, you have a problem. Your engine is either leaking oil or burning oil at an alarming rate. If you can't find a friend with the same car and engine just get a new dipstick to be safe.
Putting in too much oil can be just as damaging to your engine as running too low on oil. Get this dipstick problem taken care of so you can acturately minitor your oil situation or the few dollars you will pay for a new dipstick may seem trivial to you.
Mike
Old 05-16-2007, 04:27 PM   #8 (permalink)
nodrogkam's Avatar
So overfilling isnt good because when there is too much oil, it gets whipped around creating air bubbles and foam which doesnt do much to help lubricate parts, but this only happens when you overfill by a certain amount. I believe half a quart or more.
you could borrow someone else's dipstick, just make sure to wipe it clean so you dont mix up the oil from the two different cars.
Old 05-16-2007, 05:05 PM   #9 (permalink)
View toyomoho's Photo Gallery
How do you get this far without running out of oil. Find a long piece of fairly stiff wire and feed it down the filler hole, see what depth the oil is.
Old 05-19-2007, 03:10 PM   #10 (permalink)
View marc780's Photo Gallery
Junkyard dipstick. Ought to cost a couple bucks. Change oil (yourself) and then double check the new one's accurate. remark if needed.
Old 05-19-2007, 05:21 PM   #11 (permalink)
MAR
Future Toyota Engineer
MAR's Avatar
View MAR's Photo Gallery
Give it Viagra! It'll straighten up immediately!
I know, that was uncalled for.
MAR is offline   Reply With Quote
Old 05-20-2007, 04:00 PM   #12 (permalink)
Just an addition thought here. Is there any chance you can put the dipstick in a vice and straighten it out that way?
Mike
Transmission Dipstick car-crazy General Lexus Discussion 1 07-10-2006 04:09 PM
sputtering dipstick? holtskie Camry & Solara Lounge 12 05-11-2005 08:59 PM
messed up wiring homeguard Archived Corolla threads 2 03-26-2004 11:26 AM
