95 Camry ignition problems
My 95 Camry with 4 cyl. has been acting up lately. We replaced the fuel filter, plugs, wires, rotor and cap which helped a little but it intermittently will be hard to start (cranks but no fire) or will run rough. Other times it starts and runs normally. Happens when hot or cold.
I'm thinking either the pickup coil in the distributor (have to replace the whole assembly cause no one sells just the coil), the ignition coil or possibly a wiring issue around the distributor.
Any ideas?
