Life Expectancy of Water Pump? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2007, 10:31 AM   #1 (permalink)
View numberforty1's Photo Gallery
4th Generation Life Expectancy of Water Pump?
I just inherited a 98 Camry V6 with 160k on it, and it just had the timing belt and valve cover gaskets replaced - runs beautifully. While these replacements were definitely overdue, I'm wondering about the water pump. Haynes never gives a mileage for having it replaced, but it seems like the one part that is bound to go at some point, but that people never mention. Am I right, or will the dead thing go on forever?
So, any general mileage markers out there for when the water pump will go? The rear valve gasket seems to leak like clockwork at 150k (I have two of this model, so I'm guessing 2 out of 2 means its a trend.)
Or any other experiences with this model at 160k?
thanks
numberforty1 is offline   Reply With Quote
Old 05-17-2007, 10:35 AM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
my 95 Camry 4-cyl water pump died last year @ about 120k miles
some last for 100k, some last for 300k ... i guess it all depends on the conditions of the car/driving
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 05-17-2007, 11:30 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
It's not so much how long it will last but how much extra labor is required to replace it. Whomever did the timing belt probably should have changed the water pump when they were in there. It's only about a $40 item. But if the TB was done at regular intervals of 60K then I would not replace the water pump every 60K but every other TB change of 120K. If the water pump goes it will probably just leak at the shaft seal which will show up as coolant draining out the bottom of the TB cover. I'd leave it for now and keep an eye on any coolant leak.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-17-2007, 11:34 AM   #4 (permalink)
Venom_5's Avatar
i have to say i paid about $700 to have the water pump + timing belts [and all that other stuff down there] replaced at a local shop
Old 05-17-2007, 12:48 PM   #5 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $396985
View RningOnFumes's Photo Gallery
Water pumps are usually replaced along with the timing belts ( because of the labor invovled)
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 05-17-2007, 01:52 PM   #6 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
The Gen 4 Camry have a 90000 mile interval for the T-belts instead of the 60000 miles for Gen 3 and older.
2007 Camry 2.4L 5M
Old 05-17-2007, 02:17 PM   #7 (permalink)
View toyomoho's Photo Gallery
As Stillrunning states, replacement cost is mostly labor. At next belt change if you still have the car, put a new waterpump in. When the pump starts to fail it usually give some indication such a leaking, noise, car overheating, etc.
Also check the threads at the bottom of this page.
Old 05-17-2007, 06:02 PM   #8 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
When the car starts to overheat, replace it....
If you had the TBelt replaced by a mechanic, and they did not telly uo to replace the pump, NEVER go back to them.
5 Lug Corolla WHAT?
Old 05-18-2007, 12:35 AM   #9 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
I've had various luck with water pumps, but on cars that I owned since they were close to new with regular coolant flushes, they seem last well past 100K.
When I sold my 80 Celica GT, with 145K miles, it had the original water pump. When I sold my 88 Camry with 146K miles, it still had the original water pump. My Maxima with 184K miles still has the original water pump.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 05-18-2007, 02:37 AM   #10 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
My 87 Camry has nearly 400,000 kilometers with the original water pump. I know I know I'm crazy for not replacing it. But last time I did the timing belt, it checked out and seemed perfectly fine so I left it alone.
If it was not me but someone else driving the car I would probably replace it. I drive in the city with this car, for long trips I use my 2001. As some people stated, it is a low cost item with a potentially very high cost result if it fails.
71Corolla is offline   Reply With Quote
Old 05-18-2007, 05:08 AM   #11 (permalink)
Yea Tom I agree that with good coolant maintenance the WP will last. I think the new pumps driven off the timing belt last longer because the belt tension essentially is self adjusting. Most failures I have seen in older systems were due to over tightening of the WP pulley belt.
I would also recommend adding a coolant system lubricant like Prestone's coolant additive. It helps lubricate the impeller shaft.
If I were paying someone to do my timing belt maintenance I would have the water pump done at the same time. I go every other because I know my maintenance habits and my labor is free. I've never had a water pump failure.
Old 05-18-2007, 07:51 AM   #12 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
ive only had one water pump go bad on me, and it was on my 22-year-old suburban when it rolled 210k miles.
Old 05-18-2007, 11:37 AM   #13 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
the toyota v6 waterpumps last a good long time
you should be able to go every other timing belt change before it'll go. but if there are ANY signs of wearing, then get it replaced during your timing belt change
HaHa
Old 05-18-2007, 04:22 PM   #14 (permalink)
John
View MemphisR's Photo Gallery
my water pump went at like 60 to 65 thousand if you got the 5sfe its a non interference motor, but be prepared to push if your far from home tho! haha that nite sucked
opps im an idiot i see you clearly wrote v6 on there, so you bastards get that much mileage outta one water pump thats not fair at all
2000 Toyota Camry I4 2.2L (Super White II) - Garage Monster!
2002 Chevrolet Silverado V8 5.3L (Pewter) - Daily Driver
MemphisR is offline   Reply With Quote
Old 05-18-2007, 04:49 PM   #15 (permalink)
Venom_5's Avatar
^ i have a 4cyl and mine died @ 131k
The Free Mod Series: Part VII Cheap Water Injection Toysrme Camry & Solara Lounge 17 05-26-2010 02:13 PM
98' Camry Water Pump repair cost? mystickid 3rd & 4th Generation (1992–1996 & 1997–2001) 9 04-08-2008 06:11 PM
Help!! Water pump or oil pump is going bad?? fincoon 3rd & 4th Generation (1992–1996 & 1997–2001) 11 01-17-2008 11:37 AM
water pump change kam ae82 Archived Corolla threads 0 05-28-2003 07:24 AM
