P0755 OBD Code-Tramission Issue : please help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2007, 08:04 PM   #1 (permalink)
View rkvemuri's Photo Gallery
Hi,
My 96 camry started showing CHECK Engine light since last evening. Took it to a dealer and he reported ODB Code 0755 and said the transmission needs to be replaced. He quoted 3K for that.
The car has 130K miles on it. Engine was changed when it was 121K miles with an engine of 80K miles life on it.
What should I do? Is replacing the transmission the only way? No problem with the car right now. Runs great.
Is spending $3K worthful?
Please advise.
Thanks for your time.
RK
rkvemuri is offline   Reply With Quote
Old 05-18-2007, 10:06 AM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
You have a sticking solenoid. It might clear itself or you might try to simply drain or flush your transmission fluid. It does NOT require a new transmission!
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 05-18-2007, 11:35 AM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
^ what he said....and quite often it will even go away by itself
and even if you need a new transmission, you can get a used one dropped in at a transmission shop for probably around 1K or so. if you can do it yourself, then you can do it for the couple hundred bucks that hte tranny will cost from a junkyard
HaHa
Old 05-19-2007, 12:59 PM   #4 (permalink)
View toyomoho's Photo Gallery
Could be the solenoid valve or an internal clutch problem. The dealer should have narrowed down which. Did the dealer pull the trans oil pan and actually test the valve?
EVAP Code PO446 rooneyap 4Runner Lounge 10 11-19-2009 09:46 PM
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
how i resolved P0446 issue solidg 3rd & 4th Generation (1992–1996 & 1997–2001) 8 08-02-2007 08:15 PM
Code 71 Issue????? rfich53 Archived Corolla threads 0 08-13-2006 08:41 PM
2000 Sienna Air-Fuel Sensor OBDII code issue skriest General Discussion 0 01-31-2005 05:10 PM
