Constant misfire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-18-2007, 07:12 PM   #1 (permalink)
View killercam96's Photo Gallery
Unhappy Constant misfire
I have a problem with my camry It's a 96 with the 5sfe 2.2 I've had this problem for awhile now but it's getting more noticible over time. Ok well the check engine light has been coming on after clearing it and everytime it' been P0302 #2 cylinder misfire i've replaced everything under the hood well new cap and rotor, temp sensor,ign wires knock sensor, all are borg warner parts. Ac delco platinum plugs and all that good stuff. Well it still misses sometimes but sometimes it runs just fine. Had some exhaust work done everything is still intact but the muffler (magnaflow) and you can hear it misfire in drive or idle. I just wanna know what you guys think i've done the search thing but most have a diff problem mine is just a problem on Cyl 2
My 96 Toyota Camry
Coming back soon!!!
1995 Camry 4cyl with only 85K Makes a nice lawn ornament!!
killercam96 is offline   Reply With Quote
Old 05-18-2007, 09:06 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
have you done a compression check on that cylinder?
as well, check for bacuum leaks
HaHa
Old 05-18-2007, 09:07 PM   #3 (permalink)
Bouncing the rev limiter
92ES5sp's Avatar
View 92ES5sp's Photo Gallery
You might have a leaking valve cover gasket and tube seals allowing oil to foul the plug(s).
92ES5sp is offline   Reply With Quote
Old 05-19-2007, 02:00 AM   #4 (permalink)
View toyomoho's Photo Gallery
Could be one of many issues. Download the Gen_4 Diagnostics section, find the trouble code and follow the troubleshooting diagrams.
http://oregonstate.edu/~tongt/camry
Old 05-19-2007, 07:41 AM   #5 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Is this car breakerless ignition or distributorless ignition?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-19-2007, 12:43 PM   #6 (permalink)
Gameroom cash: $303055
A bad fuel injector could cause the misfire. The easiest way to check is to switch that #2 fuel injector with an injector from another cylinder. If the misfire code now moves to the other cylinder, you have found the problem. You may have to have new o-rings on hand for this test but they are cheap.
Mike
Old 05-20-2007, 12:27 PM   #7 (permalink)
I was thinking of bad compression on #2 because now that i remember it while i was rebuilding the motor #2 was the worst of the 4. Now i have to find someone who can do a compression check or buy a tool. Or just maybe it's the bad injector im gonna go ahead and go buy some o-rings and give that a shot 1st
My 96 Toyota Camry
Coming back soon!!!
Random misfire jthiemeyer 3rd & 4th Generation (1992–1996 & 1997–2001) 5 05-19-2010 05:34 AM
check engine light lean and misfire rflexible 1st & 2nd Generation (1983–1986 & 1987-1991) 3 11-21-2006 10:40 AM
possible lean misfire rlwjaw 89-95 Toyota Pickup/Hilux 6 01-29-2006 12:26 PM
1999 camry v6 MIL Misfire? six2tall 3rd & 4th Generation (1992–1996 & 1997–2001) 0 04-05-2005 12:29 AM
98 v6 Misfire ThurzNite 3rd & 4th Generation (1992–1996 & 1997–2001) 7 10-29-2004 11:53 PM
