Pls help ! (Experts come in) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2007, 03:00 AM   #1 (permalink)
View nuaa215's Photo Gallery
4th Generation Pls help ! (Experts come in)
1997 Camery LE
The problems starts two months ago
Symptoms:
Start engine cranking rpm ~1k -2k
RPM drop 1k --0
engine light went on
Try start a couple of times
RPM stablized at 0.3 or 0.4k
car shaking, tachometer needle shaking
everything went to normal after drive for a few minutes
If I hit gas before RPM drops to 0.
Car shakes a little bit
Everything went to normal after 1 min @ rpm >1k
This problem is on and off. Usually happens 3 times/week
Your expert opinion will be very much appreciated.
nuaa215 is offline   Reply With Quote
Old 05-22-2007, 08:57 AM   #2 (permalink)
toyocam99's Avatar
Gameroom cash: $118835
View toyocam99's Photo Gallery
If the engine is knocking while idleing or during acceleration, you may need new spark plugs and wires.
Same thing happened to my 1999 Camry.
toyocam99 is offline   Reply With Quote
Old 05-22-2007, 09:40 AM   #3 (permalink)
View solidg's Photo Gallery
find out what code your check engine light is giving
autozone will check it for free
solidg is offline   Reply With Quote
Old 05-22-2007, 10:42 AM   #4 (permalink)
Engine is not knocking during idling or acceleration.
Old 05-22-2007, 10:43 AM   #5 (permalink)
I will do that and post the codes here later.
Old 05-22-2007, 01:50 PM   #6 (permalink)
View toyomoho's Photo Gallery
IAC valve controls idle, open EGR valve can cause rough idle.
Old 05-22-2007, 02:10 PM   #7 (permalink)
USA
I may not understand your response correctly. However, it seems that my car is doing okey after it starts and drive for a while, even during idling. RPM stays at 600-800 and no shaking.
Hats off to all who responded
Moonroof experts dacecil 1st & 2nd Generation (1983–1986 & 1987-1991) 2 10-16-2006 10:01 PM
Pls lend me some advice Aven4231 Archived Corolla threads 12 12-26-2005 11:38 PM
pls help with rear tire fitment problems MR2Enthuze MR2 Forum 1 05-05-2005 09:53 PM
tercel experts junkmail914 Tercel, Paseo, Starlet, and Sera Forum 1 11-25-2004 09:44 PM
