Diameter of OEM rear stabilzer bar? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2007, 03:25 PM   #1 (permalink)
View Kiasis's Photo Gallery
4th Generation Diameter of OEM rear stabilzer bar?
Trying to stiffen the ride a bit. Anyone know the size of the stock rear stabilizer/anti-sway bar on a 99 LE 4-cyl? Wanna see how much difference between stock and Whiteline (20mm). Thanks.
Kiasis is offline   Reply With Quote
Old 05-23-2007, 05:26 PM   #2 (permalink)
Gameroom cash: $303055
On the 98 (should be the same as the 99) the rears were 5/8 diameter, which I believe is the same as 16MM.
Mike
Old 05-23-2007, 06:25 PM   #3 (permalink)
4th Generation
Thanks, Mike. According to the Whiteline conversion chart, their 20mm anti-sway bar should be approximately 144% stiffer than the 5/8 inch (15.8 mm to be anal retentive) stock stabilizer bar. That outta help a bit!! Thanks again.
Installing Front Strut Brace & Rear Sway Bar nscamry Camry & Solara Lounge 23 11-19-2005 11:10 AM
Solara rear sway bar (what and where to buy?) mox Camry & Solara Lounge 0 04-22-2005 11:18 PM
AE86 Hatch rear strut bar install question ?!?! Red_85_AE86 Archived Corolla threads 2 08-29-2004 05:35 PM
Which REAR Sway Bar? dejacky Camry & Solara Lounge 20 06-27-2004 11:55 AM
