EGR cleaning seems successful - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2007, 03:29 PM   #1 (permalink)
View mr magoo's Photo Gallery
I had alot of trouble with low idle and stalling after long highway rides last September. After consulting this forum, I isolated the EGR by unplugging the vacuum line and plugging it with a golf tee. The car ran fine in all conditions this way. Every time I reattached the vacuum line, the symptoms returned. In the mean time, I sprayed cleaner into the EGR from time to time to give it a chance. Last weekend I reattached the vacuum hose and reset the service engine light. I have since taken a 600 mile trip and driven daily without incident. I will need to go to the Massachusetts vehicle inspection program next week and am wondering if my recent resetting of code will be a problem. Everything is now running fine and the code has not recurred.
Does anyone have any other knowledge to share? Thanks a million!
mr magoo is offline   Reply With Quote
Old 05-23-2007, 03:45 PM   #2 (permalink)
I recently got a reject ... due to disconnecting the battery terminals prior to the state safety inspection. I drove 15 or 20 miles and returned for reinspection in a few days and passed.
That was here in Texas.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 05-23-2007, 03:56 PM   #3 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1075058
iTrader Score: 7 reviews
Gen5
i just had my gen5 in and they want 600 bucks to replace the EGR valve. Mine happens on cold start ups..jerks the car forward like there's a hesitation... you think cleaning it might prolong it long enough until i can afford to pay to get it fixed?? (please say yes!)
2002 Camry SE V6 "Snow White"
19x8 +48 Offset TRD rims are Foe Sale. PM For Inquiries
Old 05-23-2007, 05:13 PM   #4 (permalink)
View toyomoho's Photo Gallery
The EGR valve and pipe going to it can be cleaned of carbon. The valve may also have temp gauge that goes bad. The VSV valve that controls the EGR can go bad.
Suggest looking at the posts at the end of this page for more info, plus reading about the system by finding the correct generation manual at the link below.
http://oregonstate.edu/~tongt/camry
Old 05-23-2007, 07:29 PM   #5 (permalink)
EGR Inspection
I will post in this space next week whether the cleaning was sufficuent to pass inspection. It was successful in restoring operating under all conditions and not throwing a code. an easy test to narrow things down is to pull the vacuum hose off and plug it with a golf tee. If your poor running conditions cease, and then resume when the line is reattached, you have a clearer picture. I was also quoted $600 for replacement and can buy a new EGR for $130-$170 on line.
Old 05-23-2007, 07:41 PM   #6 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I have never replaced an EGR. Remove it and clean it. They are robust and made to last. You may need to do some scraping just be careful not to damage the poppet valve seat. I'm not sure how your Gen5 EGR is attached but you may need a crows foot to undo the large nut. Apply some PB Blaster or like overnight. Get a small wire brush and some B12 Chemtool carb & choke cleaner. Compressed air can't hurt either. If you have a hand vacuum pump you can open the valve to help flush crud off the seat.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-23-2007, 07:44 PM   #7 (permalink)
Thanks for your help and input guys/gals sorry for hijacking your Gen 4 thread. I'll try all that and report back!
Old 05-23-2007, 08:21 PM   #8 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
The nuts on mine are so rusted I won't be able to undo them. The bolts that attach the Vavle to the Throttle body are fine though. All I've done yet is spurt Throttle Body cleaner in the top vacuum line and the bigger one that connects to the tube underneath the egr while it was attached to the car, didn't make a big difference. I might try to take out the egr with the pipe under it still attached to the valve. It's a big bolt on the cylinder head that could be fairly easily taken out with a big ajustable wrench.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 05-24-2007, 06:40 PM   #9 (permalink)
That line is only used for vacuum to the dash pot that opens/closes the EGR. If you're not careful you will damage the rubber inside the dash pot. It does not carbon up.
That one goes to the modulating valve. It does get plugged with carbon as well but you need to take it all the way off and clean it out. There is also a filter on the modulating valve that can be blown out.
As for your rusted mounting bolts, I suspect they are studs. You can buy a new set and replace if you break one. Lots of PB Blaster over night will work wonders. Also try heat to help break loose. Patience will work the best.
Old 06-04-2007, 10:01 AM   #10 (permalink)
GO VOLS!!
jnoley07's Avatar
View jnoley07's Photo Gallery
USA egr valve cleaning
This weekend I removed the EGR Valve from my 01 and cleaned it out, the code had been popping for about a month now, I just kept disconnecting the batt. But after a good cleaning, it seems to be working fine. It wasn't as hard to remove as i thought it would be, it is a 12mm on top and a 10mm socket on bottom. I will let you know if it the cleaning solved the problem.
jnoley07 is offline   Reply With Quote
Old 06-04-2007, 01:15 PM   #11 (permalink)
Passed Emissions
To conclued this thread, the 96 I4 wagon passed emissions after changing nothing.
I started with severe but intermittant drivability problems at a redlight following a fast highway run. (Code: EGR). One shop wanted $600 but wasn't sure it was the cure and treated with a 3 part cleaner that did not work. Another shop drove it around for 3 weeks trying to reproduce the trouble. Said they put in cleaner, but changed nothing. someone on this site told me about the golf tee trick, so I bypassed the egr for months with no trouble at all. With emissions inspection looming I sprayed carb cleaner into the vacuum hole several times, had no drivabliliy problems for 2000 miles and finally passed Massachusetts emssions on June 1.
Thanks to all who helped me out.
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
Cleaning EGR Jayota 89-95 Toyota Pickup/Hilux 26 09-10-2010 07:24 PM
Cleaning the EGR Valve. Need help! skuba Tercel, Paseo, Starlet, and Sera Forum 4 11-22-2005 04:09 PM
EGR cleaning speedyts49 Celica Forum 20 09-24-2005 01:58 PM
Help on EGR Cleaning welin70 Archived Corolla threads 1 11-24-2004 04:10 PM
