May need to flush your coolant system, if part of it is blocked it may not be circulating through the radiator or the block properly at idle. If you flush it fill the system with clean water then add a bottle of radiator flush and drive it like that for a week or so then drain and fill with antifreeze and water.
Strangely my 3vz seems to eat coolant. I did the head gaskets and copper sprayed them, and recently did a water pump and timing belt and it hasn't changed. The coolant just seems to disappear
no trace of it anywhere either.
