Constant power source (+12Volts) at the trunk - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2007, 12:10 AM   #1 (permalink)
View camree99's Photo Gallery
I am trying to install a GPS system with a pc unit (not the portable ones) and I need a constant +12 Volts power to be connected to the pc unit. I'm wondering where I could tap from the trunk area even when the ignition switch is at "OFF" position. I was trying the courtesy switch of the trunk cover, but I get 0 volts when the trunk is open.
thanks very much for reading! hope somebody could give me some sound advise.
camree99 is offline   Reply With Quote
Old 05-24-2007, 12:32 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
to the best of my knowledge, there is no constant power source in the back of the car
all the lights are hooked up to relays, and the trunk light only gets power when the trunk is open.
I presume that you don't have a sound system in your car then?
it seems like you'll have to run a fused line from your battery to the trunk, or the closest constant 12v would be from the dash area.
HaHa
Old 05-24-2007, 12:39 AM   #3 (permalink)
thanks very much for the advise! anyway, any idea what current rating i need for the fused line?
actualy after i downloaded the electrical wiring diagram, i figured out why i get 0 volts when trunk is open. so what i'll do, i'll tap from the trunk lamp side.
thanks again!
Old 05-24-2007, 12:48 AM   #4 (permalink)
View toyomoho's Photo Gallery
See if you can tap off the power going to the trunk light switch located below where the trunk latch enters the frame.
Old 05-24-2007, 12:57 AM   #5 (permalink)
TN Pussy Man
hmmm....you know....you just made a good point....
I had presumed that the relay would be sending power from the front of the car, but that wouldn't make much sense at all. There has to be a constant 12v going to that relay in the back of the car that is activated by the trunk opening....
Good thinking.
HaHa
Old 05-24-2007, 01:03 AM   #6 (permalink)
Just assumed this would be the straightforward way to do things. Perhaps if Lucas had designed the wiring, but then the light might not work at all. The antenna motor may also have a constant source of DC power.
Old 05-24-2007, 03:14 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Tapping off the switch won't work. It works off a ground. IE: negative trigger.
"Skoolin' the unlearned!"
Old 05-24-2007, 10:02 PM   #8 (permalink)
Thanks very much! I tapped from the trunk lamp supply and it worked!
Old 05-25-2007, 08:39 PM   #9 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
^thats a constant 12v???
WhiteRabbit is offline   Reply With Quote
Old 05-26-2007, 12:16 AM   #10 (permalink)
actually yes. you can check the wiring diagram. just make sure you tap before the bulb, which makes a parallel circuit when it is turned ON when the trunk is opened.
Old 05-26-2007, 06:43 PM   #11 (permalink)
TN's furry friend
cool, good to know
I need a power source!!!!!!!! StreetThis Camry & Solara Lounge 4 10-21-2004 02:30 AM
Power Point Question... slyguy_32 Camry & Solara Lounge 1 09-17-2004 12:58 AM
Making some cool power (caution! For reference use only ) AngryAE101 Archived Corolla threads 5 11-03-2003 10:03 PM
How much RMS power is enough to power 2 JL 12W3 subs????? smokiz Audio, Video, and Security - Tech 7 02-17-2003 01:44 AM
Power Steering 86CRESSIDA86 General Discussion 8 01-31-2002 04:25 AM
