How To Change Brake Pads and Rotors? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2007, 03:33 AM   #1 (permalink)
View buzlink's Photo Gallery
3rd Generation How To Change Brake Pads and Rotors?
Does anyone have a brake chaning how-to? I'm getting ready to help my girlfriend change her brake pads and rotors, as the pad has compeltly worn away and dug into the rotor. Also the front driver side had two wheel studs break off while taking the wheel off.
Are there any special tools required to change the brake pads and rotors? How do I seperate the rotor from the wheel hub?
Thanks
96 Camry
buzlink is offline   Reply With Quote
Old 05-24-2007, 06:13 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Haynes Manual - $18
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-24-2007, 07:43 AM   #3 (permalink)
View number73forlife's Photo Gallery
Haynes manual ftw and if you have a good tool set all else that you need apply is elbow grease and time.
number73forlife is offline   Reply With Quote
Old 05-24-2007, 09:56 AM   #4 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
And a little tip. If they have not been done in years, get a breaker bar. Trust me on that. $20 at most auto stores.
5 Lug Corolla WHAT?
Old 05-24-2007, 11:31 AM   #5 (permalink)
Originally Posted by Stillrunning
Haynes Manual - $18
Got one
Old 05-24-2007, 12:27 PM   #6 (permalink)
G-ma Car? That's Right.
View Blackhawk3D's Photo Gallery
Okay, here's a quick DIY.
1. Take wheels off
2. Pop off old pads/rotors
3. Pop on new ones
4. Your done!
Once you start doing it it's pretty self explanitory, the hardest part is compressing the pistons to put the new pads on.
Blackhawk3D is offline   Reply With Quote
Old 05-24-2007, 12:36 PM   #7 (permalink)
goldi5sfe's Avatar
View goldi5sfe's Photo Gallery
no special tool reguired
1989 Camry_sold
1996 Camry_daily driver
2001 Accord V6 Coupe_still modding
goldi5sfe is offline   Reply With Quote
Old 05-24-2007, 01:55 PM   #8 (permalink)
View toyomoho's Photo Gallery
You can find Toyota OEM service info at the link below. If the system has ABS don't force the fluid back into the brake system when pushing the caliper pistons back. Open up the bleed screws to do this.
Be sure to reuse any pads shims or you may have brake squeal. Toyota pads work well and cost about the same as after market. Toyota rotors are much more expensive, suggest Brembo.
Pick up wheel studs at the dealer or autoparts shop (cost is cheap). Use a torgue wrench if you have one to install the lug nuts.
http://oregonstate.edu/~tongt/camry
Old 05-24-2007, 06:28 PM   #9 (permalink)
mr.pringles's Avatar
View mr.pringles's Photo Gallery
click for how to replace brake pads
http://www.toyotanation.com/forum/t92082.html
mr.pringles is offline   Reply With Quote
Old 05-24-2007, 10:37 PM   #10 (permalink)
View marc780's Photo Gallery
I just did my wive solara (close enough to Camry?) and the rotors were like $21. each. Since it is like $15 or more to have a rotor turned, and you have to jerk around all day hauling dirty rotors and wait for the guy etc. to get it done, i just got the cheapos!
But you can pay for toyota rotors if you must have the best - i can get by with the cheaper stuff. These rotors work fine and no noise or squaks.
Old 05-24-2007, 11:32 PM   #11 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $396985
View RningOnFumes's Photo Gallery
or another suggestion is to have a couple spares you have ready (already turned and everything) When you feel the need to swap out the rotors do it and take the ones off the wheels to the shop at your leisure.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 05-25-2007, 01:51 AM   #12 (permalink)
View chullen's Photo Gallery
don't listen to him by open the bleeding screws youa re only letting air into the system via the vaccum it is creating on the system just carefully compress the pistons a c clamp works well
1999 Camry V6 5 spd- Daily Driver
2006 Civic Si 192 whp- SOLD
1986 Corolla GTS 250 whp- SOLD
1996 Accord EX- SOLD
Production Team Leader at Mercedes Benz
chullen is offline   Reply With Quote
Old 05-25-2007, 05:45 AM   #13 (permalink)
Forcing Dirty Fluid Back into the ABS: [From Motor Service Magazine]
We believe the biggest brake bungle techs are making today is forcing caliper pistons back without clamping the hose and opening the bleeder. Since the line comes in near the bottom of the cylinder where the sediment is, this forces debris up into the ABS unit, and that will likely result in a comeback for a glowing anti-lock warning light. Just opening the bleeder as you may have done in the past isn't good enough anymore. You've got to choke off that hose. [Editor's note: you can buy inexpensive plastic pliers with rounded jaws designed to clamp rubber brake hoses without damage.
Old 05-25-2007, 07:22 AM   #14 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i changed brake pads dozens of time on my vehicle with 4 wheel ABS, i just used a c clamp to push the piston back, some fluid overflow from the brake reservior. no problem what so ever though. as soon as you open the bleeder valve, air can get in or out of the brake system, thus might require bleeding the brake again.
bronzemaxell is offline   Reply With Quote
Old 05-25-2007, 07:56 AM   #15 (permalink)
Originally Posted by bronzemaxell
i changed brake pads dozens of time on my vehicle with 4 wheel ABS, i just used a c clamp to push the piston back.
Dozens? How many miles do you get from your brakes? Anyway, I don't know how you take care of your brake fluid. I flush mine once per year so I'm probably at low risk of much dirt in the system. Most people don't maintain their fluid though. Clamping the brake line minimizes the air in the system and makes for a short bleed to pump air out of that part of the system. It also prevents having the master overflow.
Gen4 brake rotors and pads replacement Luc Hardcore Tech and Competition 5 03-06-2012 03:40 PM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Are these good rotors to get? cman2000 Camry & Solara Lounge 32 11-24-2007 01:32 AM
Should I do this or just change the pads? abimanyu Archived Corolla threads 2 09-27-2005 07:48 AM
Good discussion on x-drilled/slotted brakes EKam Hardcore Tech and Competition 44 12-29-2003 11:46 AM
