Battery/Alternator for Subs Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2007, 08:40 PM   #1 (permalink)
The Slowest of Slow
tsibole90's Avatar
View tsibole90's Photo Gallery
Hey, I've been considering getting a 2000 watt amp for two 1000 watt subs. I've heard people saying that I would need a high output alternator? Or could I just get another battery and store that one in my trunk? other suggestions are welcome. -97 4cyl. Camry LE if that helps.
tsibole90 is offline   Reply With Quote
Old 05-24-2007, 09:09 PM   #2 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Well it depends on how you play your system. Try adding the alternator first and if you feel that its not able to keep up with the load add a second battery. From what I've read its just as good as a cap. I havent actually tested my system with my HO and yellows yet but very soon...
If you like to play your system with the car off then you should look into a yellow top or odessy battery.
To keep your system thumping properly while the car is running a High output alternator is a good idea. (while car is on juice is pulled from the alternator)
Another upgrade you may want to consider to help is the BIG 3 upgrade which will either add to your current wiring or upgrade it giving you better current flow. Its a pretty simple upgrade and its pretty cheap as well.
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Curry is offline   Reply With Quote
Old 05-25-2007, 01:09 AM   #3 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
Well what brand are these subs because it is likely they don't handle that much, and the amp probably doesn't produce that many watts, unless its Kicker or MTX. Plus that is unnecessary, two 12" Kicker/MTX subs plus one of their 2-channel 1000-1400 watt amps and aGOOD BOX you will bump. You'll need to upgrade your battery most likely, and maybe get an Irragi HOA.
MIC0417 is offline   Reply With Quote
Old 05-25-2007, 01:32 AM   #4 (permalink)
View chullen's Photo Gallery
here what I would do a single ported 10" Kicker Solo X running off a Kicker 1250.1 amp and using a optima deep cycle as the capcitor. run all 2/0 gauge wire to prevent noise disturbance. If you really want bump you have to get ported as your looking for loud and ported is used more for SPL than a sealed box is used
1999 Camry V6 5 spd- Daily Driver
2006 Civic Si 192 whp- SOLD
1986 Corolla GTS 250 whp- SOLD
1996 Accord EX- SOLD
Production Team Leader at Mercedes Benz
chullen is offline   Reply With Quote
Old 05-25-2007, 01:37 AM   #5 (permalink)
my setup is this a Kicker L7 12" in a sealed box as I am going for SQ, running of a Kicker 750.1 with a Rockford Fosgate 1 Farad Cap. I am using 4 gauge wire and dynamatting the whole trunk. My headunit is a Kenwood DDX7017 and upon saving money I will be putting in MB Quart Components and Rear Coxials. I will be using a Kicker 600.4 as my amp for those speakers and tuning the sound processors with Rockford Fosgate 360 version.2. I won't get the massive bass like you are looking for but it will be clean and crisp. You don't need 2 1000watt subs and a 2000 watt amp for good solid bass.
Old 05-25-2007, 09:53 AM   #6 (permalink)
View Freshcort's Photo Gallery
tell me more about this Big 3 upgrade, please
also, links to online sources of high output alternators for a 1995 Camry LE 4cyl?
thanks
Freshcort is offline   Reply With Quote
Old 05-25-2007, 01:06 PM   #7 (permalink)
I think he means battery such as a optima deep cycle, a high output altenator like a 160 amp and a capcitor for using a 2000 watt amp i would get a 5 farad bank cap
Old 05-25-2007, 01:25 PM   #8 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
whats the diff between the optima red top and yellow top? ... i dont kno much about optimas, but i kno those are their 2 and i see both of them all the time ... is red for SUVs/Trucks or somethin?
-sry to threadjack-
oh, and the big 3 is wiring upgrade to handle more power, its not the alternator or anything like that
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 05-25-2007, 06:01 PM   #9 (permalink)
Curry's Avatar
Red top is a meant for starting. Im not sure if it can survive being discharged and charged a few times.
But i know for sure the yellow top can. Its a deep cycle battery and basically you can run it down and recharge without damaging it.
94' Camry V6 - Sold
99' GS300 - Sold
2007 Camry Sound System Question mw817 5th & 6th Generation (2002-2006 & 2007-2011) 36 12-27-2006 07:33 AM
Sub/Amp question Elizle Audio, Video, and Security - Tech 5 07-13-2006 10:42 AM
Hell Question MR2Jedi Off Topic 11 07-06-2006 10:20 PM
2007 Camry Question skippy126 5th & 6th Generation (2002-2006 & 2007-2011) 5 05-24-2006 07:47 PM
general transmission question, 2nd, 4th and reverse do not engage!! afyouthbrigade Camry & Solara Lounge 1 09-29-2005 06:58 PM
