Do 95 5SFE 5sp comes with oil cooler? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2007, 08:31 PM   #1 (permalink)
View Kitto's Photo Gallery
3rd Generation Do 95 5SFE 5sp comes with oil cooler?
As title... I seems like can't see that was installed... I compared mine to the repair manual... there was no coolant by-pass hoses around the oil filter, so can I assume that my car don't comes with one...
Kitto is offline   Reply With Quote
Old 05-26-2007, 02:01 AM   #2 (permalink)
View toyomoho's Photo Gallery
The automatic has one, same year/engine. Two hoses come off the oil filter mount.
Old 05-26-2007, 07:55 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
My 95 Auto LE has one. You may be able to add one as it's only a sandwich block between filter and oil mount. You would need water connections at by-pass though. Maybe a wrecker vehicle could provide parts to adapt. Make sure previous owner (if any) did not remove and plug connections. I don't know how efficient these water to oil coolers are as the water is about 180+ degrees. If anyone has installed an oil temp gauge they will be able to tell you what temp the oil runs.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-27-2007, 02:08 AM   #4 (permalink)
thanks for reply!
I think mine don't come with one from factory... not fair... 5spd don't have one...
I doubt there will be factory by-pass ready for the cooler... I will just leave it alone...
why I am asking this is because I plan to replace all the by-pass hoses...
Old 05-27-2007, 06:28 AM   #5 (permalink)
Kitto, the real advantage of the factory water/oil cooler probably is heating the oil to temp faster, not really cooling it. I used to install aftermarket air/oil coolers on my vehicles until I learned oil technology has really advanced to withstand higher heat and stress. If you want the protect your oil and engine I would go with a synthetic oil, which is what I do now. You get better cold start properties with high heat protection. To offset the price you can go higher miles between changes.
Old 05-28-2007, 01:24 AM   #6 (permalink)
thanks for advice, I am using synthetic oil already. I usually ran them for 5k-7k.
AE92 Oil cooler lines RA24_4_Me Archived Corolla threads 5 01-08-2007 10:09 PM
oil cooler kj_mechanic 2nd Generation (2005+) 0 11-21-2006 09:34 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 04:39 AM
Looking for a 5sfe mr2 oil cooler trd4life MR2 Forum 0 11-28-2002 12:56 PM
Oil Cooler Install Questions racerhex General Discussion 0 10-09-2002 09:47 AM
