'94 Camry V6 Powersteering Leak: root cause and repair - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2007, 07:54 AM   #1 (permalink)
pwrmactx's Avatar
View pwrmactx's Photo Gallery
3rd Generation '94 Camry V6 Powersteering Leak: root cause and repair
Looking for the root cause of my Powersteering leak on my '94 Camry V6, Brother has same leak on '94 Lexus ES300 dripping from the same area. Do not want to spend thousands of dollars ending up to be a hose. Tried SteerX helped a little but not totally. Thanks for your help... Jim
pwrmactx is offline   Reply With Quote
Old 05-26-2007, 08:09 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
First thing would be to power clean all areas where oil is now. Then check daily to see where oil is coming from. Could be cracked reservoir, pump suction line, pressure line, pulley shaft seal, steering rack.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-26-2007, 09:15 AM   #3 (permalink)
pwrmactx's Avatar
looking for common area for PS Leaks, someone has to know what is the main cause. This is a Toyota :-) Thanks
Old 05-26-2007, 09:48 AM   #4 (permalink)
View Kevs Toy's Photo Gallery
It may be the rack itself. That is common on Avalons and Camries from the mid 90s and sadly most cases I know of it was the rack itself.
Kevs Toy is offline   Reply With Quote
Old 05-26-2007, 09:56 AM   #5 (permalink)
View chullen's Photo Gallery
could also be the pump and its seals or just your high pressure line
1999 Camry V6 5 spd- Daily Driver
2006 Civic Si 192 whp- SOLD
1986 Corolla GTS 250 whp- SOLD
1996 Accord EX- SOLD
Production Team Leader at Mercedes Benz
chullen is offline   Reply With Quote
Old 05-26-2007, 04:23 PM   #6 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Over the years and across many brands and models, it has been my observation that the pressure hose near either fitting is the most common cause. That being said, and as others have noted, there is no substitute for thoroughly cleaning/degreasing the area and making a careful visual observation.
DFBonnett is offline   Reply With Quote
Old 05-27-2007, 02:19 AM   #7 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
I had the same problem and it turned out to be the rack itself. Pain in the butt it was to change.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
