Manual Window Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2007, 03:34 AM   #1 (permalink)
View CrazyCamry's Photo Gallery
Hi,
I seem to have a problem with the front windows on my car. If the window is all the way up, with the door closed one can still slide the window down from the outside.
Its a manual window, so the winder still turns on the inside when you do this. I'm quite sure its not supposed to work this way.
Giving up racing is the easiest thing in the world. I know, because I've done it thousands of times
Gen 3 200si (yes, Gen2, 3sfe in a Gen3) factory stock,
CrazyCamry is offline   Reply With Quote
Old 05-28-2007, 08:03 AM   #2 (permalink)
View Dijalnar's Photo Gallery
Australia
I had the same problem. The window would stay up but just touch it and it would just drop about 2 inches. It sounds like the gears inside the winder mechanism are worn. It is the most common problem in toyota's and the only way is to replace the whole regulator system. I paid $AU 60 from a wrecker but it was virtually brand new (got lucky ). Installing it is just a matter of removing door cover and then like 6 bolts. Took me about 20 minutes to replace.
Dijalnar is offline   Reply With Quote
Old 05-30-2007, 04:18 AM   #3 (permalink)
In my case you have to put a little effort into bringing it down, but i'm sure here in SA a would thief is gonna use more than a little force to get in.
Old 06-06-2007, 08:19 AM   #4 (permalink)
Any help?
Old 06-06-2007, 09:08 AM   #5 (permalink)
View leasaunce's Photo Gallery
yeah i think its a common prob on old cars. I noticed my brother 1991 honda civic, power window, and the window can slide down abit. I have a 98 camry, manual windows, they're still in good condition cant slide them down from outside or inside
but yeah as Dijalnar said, replace the window regulator and should fix the problem
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
manual shift question ghettosled General Discussion 11 02-09-2007 01:19 PM
power window question. kidkazi 4Runner Lounge 0 08-09-2006 12:22 AM
Gen 5.5 window cover question ASG14 5th & 6th Generation (2002-2006 & 2007-2011) 3 11-07-2004 10:37 PM
Broken power window question URGENT! onestyle Celica Forum 5 10-20-2004 12:14 PM
