'97 Camry turns off immediately after start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-30-2007, 09:03 AM   #1 (permalink)
View djstylze's Photo Gallery
Help!!
I have a 1997 Toyota Camry with about 145K miles on it and the car drove fine up until this morning. The car starts but turns off the moment it runs. I tried twice and on the 3rd time tried to give it gas as it started - no luck.
Oh, its an automatic as well.
Thank you
Mike
djstylze is offline   Reply With Quote
Old 05-30-2007, 09:59 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Could be as simple as a worn ignition key cylinder. When it starts on, "Start" position and you release it to "Run" position try wiggling and pushing it in that position and see if it trys to stay running.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-30-2007, 01:45 PM   #3 (permalink)
Thanks for the ideas! I'll try them when I get home.
Old 05-30-2007, 01:59 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
Originally Posted by JJJJJJ
one of your electrical sensors like MAF is unplugged or your EFI fuse is blown.
I'm going with that
HaHa
Old 05-30-2007, 03:51 PM   #5 (permalink)
View toyomoho's Photo Gallery
If MAF sensor try pressing on the gas pedal when starting and see if it runs.
Old 05-30-2007, 06:19 PM   #6 (permalink)
Ok, you guys are good! I held the gas and it stayed on this time. After a good 30 seconds of 1k rpm's.. the car stayed at a very low idle (~800rpms).
After driving it around, it turned on ok, but again with the low rpms. So does that mean there's a blown EFI fuse or do I need to replace the MAF sensor?
Thank you again!!
Mike
edit: The fuse is good.
Old 05-30-2007, 07:29 PM   #7 (permalink)
Around 800 rpm is normal when engine warm. Is the RPM lower then this, say 500 rpm? How does the car drive when not at idle? If OK, check the IAC valve, might need cleaning.. If the car has A/C, turn it on with engine at idle. See if the idle picks up to 1000-1200 rpm. If A/C is running OK, but idle is low might be idle up system.
Old 05-31-2007, 02:11 AM   #8 (permalink)
TN Pussy Man
if the car runs, then it's not an efi fuse problem
check your iacv as toyomoho said, and it wouldn't hurt to clean your maf while you're at it as well
HaHa
Old 05-31-2007, 04:08 AM   #9 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
Don't forget that a bad idle could also be a dirty TB.
MIC0417 is offline   Reply With Quote
Old 05-31-2007, 07:35 AM   #10 (permalink)
Unco's Avatar
View Unco's Photo Gallery
methinks IAC valve too. if it's running fine apart from idle, that's usually the culprit. try cleaning it out, there's a good guide in the forums somewhere, just do a search for IAC. also, as MIC0417 mentioned, take a quick look at your TB, it only takes a minute to undo the hose clamps. maybe clean that out first and see if you notice any difference, then go for the IAC valve.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 05-31-2007, 07:44 AM   #11 (permalink)
I'll try both today after work - you guys are great!!
Old 07-14-2007, 05:04 PM   #12 (permalink)
View upsgalaxy's Photo Gallery
carifying shortnames and help solve problem
i have an automatic '97 camry (120K miles) with the same issue as well (low rpm and engine dies at startup).
it happens about once almost every two weeks.
the idle at startup is not even at 500 rpm.
and sometimes when i hit on the gas, it dies...need to restart again, and took maybe about 3 times.
i haven't tried any of the recommendation mentioned before, since I don't a lot of the short terms being used (MAF, EFI, TB, etc)
Can someone explain each of the terms used?
I'm going to try turning on the A/C first.
Hope that will work.
Thanks.
upsgalaxy is offline   Reply With Quote
Old 07-14-2007, 05:21 PM   #13 (permalink)
Gameroom cash: $303055
"i haven't tried any of the recommendation mentioned before, since I don't a lot of the short terms being used (MAF, EFI, TB, etc)
MAF = mass airflow sensor
EFI = electronic fuel injection
TB = throttle body (can also be used for timing belt)
Mike
WARM start problems for 97 Camry V6 DaFOBulous1 3rd & 4th Generation (1992–1996 & 1997–2001) 7 02-16-2007 04:47 PM
94 Camry Won't Start FSIMENTAL 3rd & 4th Generation (1992–1996 & 1997–2001) 2 01-18-2007 03:15 PM
Remote Start Help (Viper 160XV) LE05 Audio, Video, and Security - Tech 9 11-09-2006 03:26 PM
My '93 Camry LE wont start... Anyone know why? philosophy251 3rd & 4th Generation (1992–1996 & 1997–2001) 5 08-29-2005 08:39 AM
Overheating (again) + sputter start = end of Camry? Redline Camry & Solara Lounge 6 04-20-2005 11:51 PM
