HIDs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-30-2007, 09:44 PM   #1 (permalink)
View Kalgatha's Photo Gallery
HIDs
Hi guys, I have been looking around alot and am thinking seriously about purchaseing a HID conversion kit. Other than power efficiency and greater output are there any other pros for HIDs? What kind of kit do I need? I was looking on the XenonDepot site and they have about 15 differant kits and I have no idea what the difference is. How hard would it be to install it in my gen 4 camry? should I replace anything else other than what the kit gives me? I saw that some of the kits have HI/LOW beams, should I get one of those? Im sure theres more but I can't think of it right now >.< thanx guys
Kalgatha is offline   Reply With Quote
Old 05-30-2007, 09:55 PM   #2 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Stay away from kits and go spend some time reading here:
Everything you need to know about them, how they work, pros, cons and all that jazz.
http://www.hidplanet.com/forums/
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Curry is offline   Reply With Quote
Old 05-30-2007, 09:57 PM   #3 (permalink)
mr.pringles's Avatar
View mr.pringles's Photo Gallery
dont neccessarily stay away from HID kits, just do a projector retrofit first because otherwise with halogen headlights and HID produces a bad output, while projectors and HID are the best way to go, just like a real luxury car
mr.pringles is offline   Reply With Quote
Old 05-30-2007, 10:44 PM   #4 (permalink)
Curry's Avatar
What I mean by "kits" are the cheap knock offs.
94' Camry V6 - Sold
99' GS300 - Sold
Old 05-30-2007, 11:36 PM   #5 (permalink)
What about the ones from XenonDepot? this thread (http://www.toyotanation.com/forum/t194054.html) says there good. Are they?
Old 05-30-2007, 11:54 PM   #6 (permalink)
Curry's Avatar
Got this info off HID Planet. If you havent already checked it out give it a look.
HID kits are illegal due to the glare that they cause. Glare is Light that is emitted in a Uncontrollable path. When light is traveling in a uncontrollable path it can hit other vehicle operators affecting there vision because of the High amount of uncontrollable light that is being Emitted from a HID kit in a standard Halogen housing. If you have ever turned a flashlight on right in front of your face while it is dark out, that is the same feeling that the other drivers on the road experience from a standard HID kit.
OEM Vehicles such as Mercedes, BMW, Audi, Lexus are all equipped with HID or Xenon Headlights. Some use reflector housing’s without projectors. Others use HID projectors.
The Lexus IS300 is a Prime Example of a HID reflector housing. It does not use a Projector. It uses a Specially designed Reflector housing that is meant to use HID. This does not create the Super sharp cutoff. But it does control where the light is being Emitted.
Other vehicles such as the Honda S2000 Use HID projectors, These Projectors are meant to use HID. They are Specially Designed and have been tested Hundreds of times to get the right projection of light while maintaining a Good Cutoff.
To date, NHTSA has investigated 24 HID conversion kit suppliers; all investigations have resulted in recalls or termination of sales.
RM Racing
Astex USA
Kmax International
FET, Inc.
J. Liu LLC
Gourmet Garage
JC Whitney
Lighting Research
SPW Industries, Inc.
Pacific Micro-lite
McCulloch Motors, Inc.
Santeca Electronics
JF Manufacturing
Streetglow, Inc.
Outback Products, Inc.
Nu Performance
GR Motorsports, Inc.
Global Premier
New Clor
Importhookup.com
DG International
MTC Lighting
Umnitza
Liteglow
American Products Company
94' Camry V6 - Sold
99' GS300 - Sold
Old 05-31-2007, 06:17 AM   #7 (permalink)
Home of the Demon Cam
CamryOwner98's Avatar
View CamryOwner98's Photo Gallery
Kits = not reliable (ballasts with short life, bulb burns out quick)
OEM kits = reliable (high quality, durable)
Like mentioned before, halogen headlights aren't made for the intense output of HID bulbs. Therefore, you'll need HID projectors to properly disperse the lighting for an even and wide illumination.
Just simply showing kits into halogen housing will not give you the HID benefits. It will cause glare and give you illumination with little to no control. In some cases, worse than halogen because it's not meant for that type of bulb.
X2 for HID Planet. Read up. I learn all I know from there basically.
Mods:
HID TL Bi-Xenon Projectors~Auxillary Bosch Mini Projectors~
Superflux LED Tails~
Euro guages~Halogen Fogs~
CamryOwner98 is offline   Reply With Quote
Old 05-31-2007, 09:53 AM   #8 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
this is waht HIDs look like in a non projector housing.
scattered and rather pointless since most of the light is dispursed so much that ur factory halogens are almost better.
this is what other drivers see.
be kind...dont blind.(saw that on a sign in SC one time )
now personally i like the look of the gen3 without projectors better, but it really is the way to go.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 05-31-2007, 09:59 AM   #9 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
might as well get Sylvania Cool Blue's instead of HID if you want that look ^
like everyone else has said, put projectors on if you use HID on a gen3
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 05-31-2007, 11:06 AM   #10 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
I know I have a completely different size bulb, but they are basically the same.
If all you want is a cool blue effect, just get some high temp color bulbs. I have 7000K in mine (see the sig). They do a decent job of lighting up the road, but I have them for show.
And for all the bashers out there, my true HID Conversion Kit is on backorder from the XenonDepot, but should be here early June.
geoff5093 is offline   Reply With Quote
Old 05-31-2007, 11:23 AM   #11 (permalink)
Venom_5's Avatar
geoff, ur car looks clean anyways ... but put some pics up when ur kit arrives!
Old 05-31-2007, 09:17 PM   #12 (permalink)
how much money/customizing would i have to do to get projectors put in?
Old 05-31-2007, 09:22 PM   #13 (permalink)
Venom_5's Avatar
u can do it urself like Curry ... check his posts in the Gen 3/4 section ... he's only paying like $20 tops i bet
or you could make it cost like $300 if you want to be really professional about it
it all depends on how much youre willing to do
Old 05-31-2007, 09:29 PM   #14 (permalink)
is there a DIY I could look at?
scratch that i found one.
what about a wireing harness? i would need one of those wouldn't I?
Old 05-31-2007, 09:46 PM   #15 (permalink)
geoff5093's Avatar
Thanks, it's backordered until June 2nd or 4th. I also have TRD springs sitting in my garage waiting to be installed as well
Real HID's not necessarily "better" fredster34 5th & 6th Generation (2002-2006 & 2007-2011) 26 12-11-2006 06:06 PM
hids are nice. but what about your 9005 highs? JustAnotherAsian 5th & 6th Generation (2002-2006 & 2007-2011) 6 11-06-2006 04:55 PM
what's the difference between these HIDs? elvasoshexai General Discussion 15 11-18-2004 12:07 PM
