engine temp gauge is LOW - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2007, 12:35 AM   #1 (permalink)
View 95.camry.le's Photo Gallery
95 Camry LE
297000 miles
this past winter I noticed that my engine temp gage was always hovering at/around/below the lowest mark of the gauge. my car would take so long to reach levels above the lowest mark at idle and during driving, it would often decrease in temperature (due to cold air cooling???). Often times after a few minutes of driving the gage would dip down to the lowest mark or even below. I noticed that until the temp gage reached a certain point, I could only drive in lowest gears (1st, 2nd gear) ...causing high RPMs.
is this indication of a problem? in the years past, my engine temp would always hover around the middle even during the cold east-coast winters. not so anymore! whats going on here? is this typical of gen 3/4 toyotas that are aging?
im not an expert, just looking for insight that may save time/money.
thanks, steve
95.camry.le is offline   Reply With Quote
Old 05-31-2007, 12:52 AM   #2 (permalink)
View toyomoho's Photo Gallery
Sounds like the thermostat is stuck open. Long warm-ups, low coolant temps/coolant temp varies (as per temperature gauge indication). The O/D will also not engage at low coolant temps. Common problem, low cost repair.
Old 05-31-2007, 11:51 AM   #3 (permalink)
tks for the info.
i should also mention that when i am driving and come to a stop with idle (like at a red light) the temp gauge will slowly climb up to a normal range...but when i start driving again it dips all the way down.
does this shed anymore light on the issue?
thanks.
Old 05-31-2007, 11:53 AM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
yup...sounds like the thermostat
HaHa
Old 05-31-2007, 01:42 PM   #5 (permalink)
Gameroom cash: $303055
As Toyomoho and Eye8Pussies said, replace the thermostat; it's stuck in the open position. These are the classic symptoms. Replace it and the gasket (actually an o-ring) and then thoroughly bleed the cooling system. I always use Toyota OEM thermostats on my cars, since they aren't much more money than aftermarket. Do it soon, as this is also decreasing your fuel mileage.
Mike
Old 06-01-2007, 11:15 AM   #6 (permalink)
thanks everyone!
20R ENGINE REBUILD FROM HELL! (Part Three) nwdetectorist Pre-88 Toyota Pickup/Hilux 1 08-09-2007 07:30 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
Low Engine Temp Rew General Discussion 6 11-23-2004 07:55 PM
Temp gauge relay [gen2] Zfreeman 1st & 2nd Generation (1983–1986 & 1987-1991) 9 08-21-2004 07:00 PM
Help on hooking up oil pressure gauge & coolant temp gauge? Camdaddy Camry & Solara Lounge 4 01-20-2004 05:57 AM
