steering noise>anybody knows? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2007, 08:35 AM   #1 (permalink)
toyotaluv1967's Avatar
View toyotaluv1967's Photo Gallery
Hi i kow someone here knows what it is i already know there needs to be more money spent ok here we go. when i turn the steering wheel it makes a weird rubbing noise.i checked power steering fluid and also had it changed not long ago. can it be the cv joints or anybody got an idea?????thanks for any help
toyotaluv1967 is offline   Reply With Quote
Old 06-02-2007, 09:58 AM   #2 (permalink)
ycartf's Avatar
View ycartf's Photo Gallery
CV joints or axles would give you a clicking sound and usually while making turns under speed. The rubbing sound you are describing sounds very generic. Can you be more specific as to where it is coming from and exactly what it sounds like? Does it sound like something rubbing against something else (lower pitched) or higher pitched like a squeal / whine/ is it constant / does anything make it worse or better?
Tracy Faulkner
ycartf is offline   Reply With Quote
Old 06-02-2007, 04:06 PM   #3 (permalink)
View Surfslinger's Photo Gallery
When sitting still and turning the wheel, my 94 makes a light popping sound... Pretty sure it's related to the strut bearing/mount. Noise is less when warm outside, and worse when cold.
If moving, as mentioned it could be the CV joint popping because the boot was ripped, and there is no more grease to lube the joint.
More info would be helpful.
Surfslinger is offline   Reply With Quote
Old 06-02-2007, 10:16 PM   #4 (permalink)
View sweetsocaking's Photo Gallery
Nope the noise that your refering to is the same exact noise i have on mine if u put ur car up on a hoise and hold one side of the wheel and turn it u will see that the rubber that ur sprigs sits on is turning as well right between the strut and the sprig at the front right where ur spring sits on ur strut check both sides and u wil see for your self.
sweetsocaking is offline   Reply With Quote
Old 06-03-2007, 03:11 PM   #5 (permalink)
i hear it mostly when the engine on and the car is parked. it sounds like it is coming from where the steeringwheel comes out to the engine and it has a joint there where it is moving when you turn the steering wheel. it is a kinda cracking sound.that's the best i can describe it.
Curious about swapping steering wheels. Driver General Discussion 3 02-21-2007 03:00 PM
Steering knuckle and hub assembly abew330 Camry & Solara Lounge 0 02-07-2007 06:02 PM
Steering troubles... grndslm Archived Corolla threads 5 10-31-2006 12:05 PM
How-To: 89+ Non-Airbag Steering Wheel into Pre-89 (MKIII) Jeff Lange Supra Forum 1 10-13-2005 01:17 AM
No horn / steering wheel basic electrical stilllearning6 Celica Forum 1 03-17-2005 07:38 AM
