Which flasher do I need??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2007, 01:31 PM   #1 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
For the turn signal flasher (getting one so I can put in LEDs), which of the following do I need?:
FL2
FL3
CF12ANL-01
CF13GL-02
CF13JL-02
EP27L
EP29L
CF18-08
Thanks!
WhiteRabbit is offline   Reply With Quote
Old 06-05-2007, 05:45 PM   #2 (permalink)
TN's furry friend
anyone know the correct size/part #?
Old 06-05-2007, 06:24 PM   #3 (permalink)
View toyomoho's Photo Gallery
Someone on Ebay was selling flasher units for Toyota for use with LED's. If you use a standard flasher with LED's, the flash rate will be high unless resistors are used.
Old 06-06-2007, 11:59 AM   #4 (permalink)
TN's furry friend
i guess i just need a standard 3 pin one...
Old 06-06-2007, 01:08 PM   #5 (permalink)
TN's furry friend
alright figured it out finally, EP35, woo hoo!
Old 06-06-2007, 01:42 PM   #6 (permalink)
Check out this site.
http://autolumination.com/equalizers.htm
location of signal flasher on paseo MikeyMik Tercel, Paseo, Starlet, and Sera Forum 1 02-28-2007 09:53 PM
LED Flasher on DTRL System? Pb? speedwaydc 2nd Generation (2005+) 4 02-12-2007 11:30 PM
1995 Turn Signal Flasher Location spoonieluv 3rd & 4th Generation (1992–1996 & 1997–2001) 3 04-04-2005 08:37 PM
flasher problem DavePont Camry & Solara Lounge 3 03-20-2005 07:38 PM
Emergency Flasher not working taimurakhter Camry & Solara Lounge 0 12-23-2004 07:58 PM
