Just purchased a 1992 LE i4 5spd manual - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2007, 12:45 AM   #1 (permalink)
View bullycanadian's Photo Gallery
Paid $2125 Canadian for it.
It has a few problems. Windshield washer fluid doesnt work shot out (maybe motor?) Driver side view mirror is broken/mission. Lastly the suspension is floaty and makes a shimming noise going over bumps. Other than that everything else works GREAT.
Any clue on how easy it is to fix the side view mirror? Will this one ( http://cgi.ebay.ca/92-96-TOYOTA-CAMR...QQcmdZViewItem ) work? My car was made in Japan, will that make it a big obstacle?
And for the suspension problem, what would it most likely be? Struts? Ball Bearings? how can i diagnose myself???
bullycanadian is offline   Reply With Quote
Old 06-05-2007, 12:47 AM   #2 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Struts and mount.
Any Gen 3 mirror should be fine.
5 Lug Corolla WHAT?
Old 06-05-2007, 11:00 AM   #3 (permalink)
Heat's Avatar
View Heat's Photo Gallery
To give you an idea on the price, my mom had the four struts replaced and new CV boots put on to her (now mine) 1995 Camry LE for about US$1,000. Not sure if that was a good price or not but is just a number to keep in mind.
Heat is offline   Reply With Quote
Old 06-05-2007, 11:56 AM   #4 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
iTrader Score: 6 reviews
View Rdizzle's Photo Gallery
^wow, why didn't you just bend over and KY up?
Originally Posted by DarkMastyr View Post
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
[U]
http://www.cardomain.com/ride/398065...ry-le-coupe-2d
Rdizzle is offline   Reply With Quote
Old 06-05-2007, 08:53 PM   #5 (permalink)
$1000 US??? Thats too expensive isnt it???? Dang, I hope I didn't get a money pit, just found out the fuel tank is leaking too (filled up my gas up all the way today and smelt gas, looked under and looks like the gas tank is leaking.)
Any other estimates for how much it will cost to get my tank replaced and my struts and perhaps strut mounts replaced???
Old 06-05-2007, 10:31 PM   #6 (permalink)
View sweetsocaking's Photo Gallery
Hey i live in toronto and i changed the stuts on mine all four the 2 fronts were $253 and backs were $178 all monroe gas matic the strut mounts were $125 each so $500 in total so yea its pricey but definitel worth it.
sweetsocaking is offline   Reply With Quote
Old 06-05-2007, 11:03 PM   #7 (permalink)
5S-FU
View Sniperdude's Photo Gallery
Damn dude, you got shafted.
I live near chicago and I can get the entire axle and struts (parts included) for less than 600.
Sniperdude is offline   Reply With Quote
Old 06-06-2007, 12:39 AM   #8 (permalink)
Hey where did you get the struts/strut mounts changed? Im near toronto and am willing to go to the same place. PM me if you can! thanks!
Old 06-06-2007, 07:36 AM   #9 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
I probably paid $700 for all struts and mounts except the drivers side, so $1000 doesnt seem insanely expensive.
geoff5093 is offline   Reply With Quote
Old 06-06-2007, 09:09 AM   #10 (permalink)
Heat's Avatar
I'll need to look at the receipt to see exactly how much it was, though remember that it included at least a couple new boots along with the struts.
I didn't pay it, it was my 70 year old mom who had the work done and was telling me about it maybe six or eight months after the fact. Maybe it was $900, maybe she had brake work done too, I don't know, I wasn't there, but if the receipt is there I'll know what was done.
She recently bought a new car ('07 Honda Accord SE) and rather than trade in the '95 Camry with 155,000 miles she just gave it to me, the dealer wouldn't have given her much for it. I'll look for the receipt tonight, if I find it I can tell you exactly how much this one mechanic charged for the four struts.
Old 06-06-2007, 02:55 PM   #11 (permalink)
Gameroom cash: $303055
Consider doing the suspension work yourself using the Monroe Quick Struts. They are a 1-piece strut, spring, and strut mount assembly, along with all the boots and rubber pieces. You just unbolt the old strut assemblies and bolt these in. There is no spring to compress so they are an easy DIY change. They are also more economical than buying all the parts individually. I paid $170 a side for the rear assemblies for my 98 Camry. The only other advice I can give you is to spray all the bolts down with a good penetrating oil like PB Blaster for a couple of days prior to removing anything. The sway bar end links were a particular item I worried about possibly breaking during removal of the old assemblies, but spraying them down did the trick. I sprayed them down each day for 2 days prior to dissambly, and then drove the car allowing the vibration of driving to work the penetrating oil in.
Mike
Old 06-07-2007, 10:50 PM   #12 (permalink)
Mike
That actually sounds like a great idea. Im gonna check some local shops today and see if they carry them, if they do, hopefully will be installed on Sunday!
Old 06-07-2007, 11:03 PM   #13 (permalink)
View 92killacam's Photo Gallery
It sounds like your filler neck is rotted out, either way Gas Tank Exchange did awesome work on my tank/filler neck...and their pricing is pretty good as well they are recommended by the Toyota Techs that ive talked to around here....The shop is up by the woodbine racetrack:
http://www.yellowpages.ca/business/0...ound&pstype=si
92killacam is offline   Reply With Quote
Old 06-07-2007, 11:12 PM   #14 (permalink)
Any idea if these springs/struts ( http://cgi.ebay.ca/KYB-GR-2-STRUTS-S...QQcmdZViewItem ) will fit on my 1992 Camry????? if yes I have a shop here that is willing to install them for $200.... Will they fit?
Old 06-08-2007, 07:53 AM   #15 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i have KYB GR2 on my 94 V6 LE, they are just a little bit stiffer than OEM, if you are looking to spend that kinda money, look at tokico also. by the way, if you are going to replace spring to drop an inch or two as well, you will get less body roll, but more harsh and bumpy ride.
bronzemaxell is offline   Reply With Quote
1992 Previa LE Owner mrkanda Introduce Yourself Here 0 05-24-2006 10:53 PM
'97 Camry LE I4 auto N4TECguy Introduce Yourself Here 4 03-30-2004 06:37 PM
FS: 1992 Camry LE Parts gcs118 Vehicles 47 10-29-2003 02:02 PM
Gen 3 I4 model differences DX, LE, XLE, SE ?????? MCX20-XLS 3rd & 4th Generation (1992–1996 & 1997–2001) 26 12-11-2002 08:39 PM
