egr help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2007, 03:25 PM   #1 (permalink)
GO VOLS!!
jnoley07's Avatar
View jnoley07's Photo Gallery
egr help
OK, I have an 01, 4cyl, my check engine light keeps coming on, i went to autozone for a reading, and it turns out to be the egr valve, so i take the thing off, clean it up and reinstall it, and reset the computer the car ran good for a couple of days and now the light is back on, what gives. the car doesnt run poorly at all, everything seems normal except for the check engine light coming on.
any ideas? Trying to keep from dumping the money for a valve.
jnoley07 is offline   Reply With Quote
Old 06-05-2007, 04:00 PM   #2 (permalink)
View toyomoho's Photo Gallery
What is the code?
Old 06-05-2007, 07:07 PM   #3 (permalink)
View cascadedhart's Photo Gallery
delt it
cascadedhart is offline   Reply With Quote
Old 06-06-2007, 07:55 AM   #4 (permalink)
GO VOLS!!
jnoley07's Avatar
I dont remember the code it was a while ago when i went, i believe it was a P0401 or P0402. I am going back over there today to get another reading to make sure it isnt something else.
Old 06-07-2007, 08:40 AM   #5 (permalink)
GO VOLS!!
jnoley07's Avatar
ok, it is definitly P0401. I am thinking it is the VSV, from what i have read from other peoples woes, does anyone know where this sucker is and does anyone have any pics. Also anyone know how much this thing may cost.
Old 06-08-2007, 11:42 PM   #6 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
I have a P0446 and recently replaced my VSV for EVAP wich is located just to the right of the air filter box. It's an easy fix, part cost me around 50-55$ CDN, it did not fix my problem, but could very well fix yours.
It has two vacuum tubes, one tube goes to the top of the throttle body and another one goes down and all the way to the charcoal canister, at the rear of the car.
There are two more VSVs one the whole system, one behind the engine block and another one on the canister, but they are not easiy to get to.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 06-09-2007, 07:21 AM   #7 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Originally Posted by jnoley07
I am thinking it is the VSV,....anyone know how much this thing may cost.
Why don't you test it before replacing it?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 06-10-2007, 12:10 AM   #8 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
and get the dtc's cleared? you can clear the codes w/out loosing your "memory" just need a code reader. also, removing the battery cable sets a code in some cars. anyway, removing the cable to clear the code/memory is fine, your computer tests itself every time you drive, and dosent need previous memory to run unless there is an important sensor problem.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 06-10-2007, 12:23 AM   #9 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
sorry for the thread jack, but i changed my VSV code still came back and im trying to take off my egr but i need some help, how and if it easy to remove because there a metal line coming out form it and i believe that the line that clogged with carbon buildup and i dont want to mess up the valve can someone like write up the process of removing...
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 06-10-2007, 12:47 AM   #10 (permalink)
View chullen's Photo Gallery
it could be the vsv on the charcoal canister in which case you might just put a new canister in since it takes as much time but would give u a new evap canister and vsv
1999 Camry V6 5 spd- Daily Driver
2006 Civic Si 192 whp- SOLD
1986 Corolla GTS 250 whp- SOLD
1996 Accord EX- SOLD
Production Team Leader at Mercedes Benz
chullen is offline   Reply With Quote
Old 06-10-2007, 05:43 AM   #11 (permalink)
Don't know your engine but the large nut on the bottom of the EGR is a 15/16". You will need some PB Blaster to soak overnight and a 1/2" drive 15/16" crows foot.
Old 06-10-2007, 08:47 AM   #12 (permalink)
GO VOLS!!
jnoley07's Avatar
CEL off
ok i got in touch with my local stealership and the part (egr vsv)cost 70.55 and i was going to drive down there and get it after work, but the CEL went off and hasnt returned in the last couple of days. i am going to wait to buy it til the CEL is on and see if it is truly the vsv. Thanks guys for the help, i will post again if it comes back on and if the vsv fixes it.
Old 06-10-2007, 03:05 PM   #13 (permalink)
Creeps228's Avatar
stillrunning its a i4
MR2: 7A-GE
Old 06-10-2007, 05:52 PM   #14 (permalink)
View marc780's Photo Gallery
I'd try one from a junkyard engine first, do they have pic-your-parts down there? I'll bet you could find one almost good as new for a couple bucks-(they use this engine on a lot of toyota models dont they, or only for camry? )
Old 06-10-2007, 06:56 PM   #15 (permalink)
its a i4
Sorry, didn't read the text in your car pics. I don't know how the 99 four attaches the EGR. You'll just have to look and see. Could be two bolt flange and not a single nut as is mine.
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
Do-It-Yourself : Check Engine Light - Diagnosis bonnie* Archived Corolla threads 5 01-01-2007 02:12 AM
1990 Camry 3sfe EGR valve Kep 1st & 2nd Generation (1983–1986 & 1987-1991) 0 08-29-2005 10:33 AM
Egr system, What a pain in the rear! commutercar Archived Corolla threads 6 08-14-2005 02:46 AM
