Loose Terminal Clamp Causing No Start? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2007, 09:09 AM   #1 (permalink)
View numberforty1's Photo Gallery
4th Generation Loose Terminal Clamp Causing No Start?
The past two times I have tried to start the car, the lights and dash have come on fine, but as soon as I turn to ignition everything goes completely dead. So, I thought to myself, bad battery (even though I got the battery a year ago).
I took it to Firestone, and they said they tested the electrical system and it works fine. They said that after testing the system, they just pushed down on the positive terminal clamp and the car started right up. Apparently the clamps can expand with heat and age and no longer carry sufficient current. My question is, how could the battery terminal be "connected enough" to run the lights and stuff in the cab, but not "connected enough" to start the engine? Is the voltage output somehow related to the tightness of the clamp? That just doesnt seem to make sense to me. My impression is that the current will travel pretty much the same as long as the terminals are at least touching somewhat. Anyone able to confirm or deny this?
And secondly, I bought a new clamp, but it doesn't look anything like the clamp that is on there now. Are there different clamps that connect in different ways?
Thanks
98 Camry V6
numberforty1 is offline   Reply With Quote
Old 06-06-2007, 10:01 AM   #2 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
They would be correct. In fact, I've seen cases where you couldn't tighten the terminal any more yet there was too much resistance in the connection to allow starting amps to flow. It would require removing the terminal and wiping off a thin clear 'film' which can build up. (I'm not talking about blue/green corrosion- just a 'wet-looking' film.) Explaining current flow however, is too complicated to get into here. (There's still some argument as to if it flows + to - or - to +. ) As for Part Two, yes, there are several different styles of clamps. They include side-mount and top-post and some clamp to a single wire (or maybe more) while some have a wing nut and stud for multiple wires and even combinations of both.
Dave's is offline   Reply With Quote
Old 06-06-2007, 10:36 AM   #3 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
gf's friends 89 camry had the problem. replaced her terminals with those $.99 advance auto ones and voila!
just take out the wires in the old clamp and put it on the new one.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 06-06-2007, 11:13 AM   #4 (permalink)
If you have access to an instrument called a voltmeter, you can actually measure the voltage between the metal cable clamp and the metal battery post, at either the positive or negative battery terminals. If this voltage measurement is anything other 0.0, then you have a faulty, or dirty, clamp to post connection. The use of a special wire terminal brush is recommended to insure that both the battery post and the cable clamp are clean, if not shiny, prior to tightening the clamp bolts. The lead material of the battery posts is given to oxidizing quickly, even if just exposed to air. For the best possible electrical connection, it would be advisable to wire brush the battery post and also the cable clamp connection surface just prior to assembly, and torquing the clamp bolt. ... If you have a side terminal battery, a plain small wire brush is useful for this purpose.
... for the voltmeter test to actually work, you probably need to have some load current going, like turning on the headlights.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 06-06-2007, 12:04 PM   #5 (permalink)
View fox_prime's Photo Gallery
Originally Posted by Dave's
...Explaining current flow however, is too complicated to get into here. (There's still some argument as to if it flows + to - or - to +. ) ...
Current flows from - to + because of the negative charge in electrons attract to the opposite end where the positive charges do not move.
fox_prime is offline   Reply With Quote
Old 06-06-2007, 01:09 PM   #6 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
^But that's just the electron theory side of things...
BlueFusion6851 is offline   Reply With Quote
Old 06-06-2007, 02:21 PM   #7 (permalink)
Dave's
Thanks- all those years of electronics training and I could have just asked TN.
Old 06-06-2007, 02:38 PM   #8 (permalink)
^ lol...I'm an E.E. major, graduating later this year. So this stuff is still fresh in my head.
Old 06-06-2007, 03:09 PM   #9 (permalink)
Coming back onto this topic...
Originally Posted by numberforty1
...My question is, how could the battery terminal be "connected enough" to run the lights and stuff in the cab, but not "connected enough" to start the engine? Is the voltage output somehow related to the tightness of the clamp? That just doesnt seem to make sense to me. My impression is that the current will travel pretty much the same as long as the terminals are at least touching somewhat. Anyone able to confirm or deny this?
More contact = more surface area = more current flow. Current flow becomes restricted under smaller gauge wires. Current does travel in the same direction, but there will not be enough flow if the contact is loose. Think of an analogy about a hallway. With a wide hallway, more people can pass through. However with a narrow hallway, less people will pass through. So overall, your engine requires much more starting power than your lights do.
Make sure your terminals (and clamps) are also clean for good contact. Any oxide, rust or corrosion can be easily taken off using a battery terminal cleaner. Once done, I think you're supposed to apply a certain chemical (to prevent corrosion) before putting the clamp back on. Once done, put on the clamp and tighten that sucker until it doesn't move at all. Any excess or ugly-looking stuff (such as oxide or corrosion) acts like resistance. And you know more resistance = less current flow.
The usual existing clamp is the universal type. There are several other adaptors to use (especially for car audio equipment), so you may have to browse a local car store (such as Kragen or Autozone) until you find one that suits your taste. Worst case scenario, just buy the clamp at the dealership.
Hope this helps,
fox_prime
Old 06-06-2007, 07:24 PM   #10 (permalink)
View marc780's Photo Gallery
Just shim the clamp. Any conductive piece of metal will do, a crimp on connector, etc. You can always take a hammer and smash a penny flat, and this will work fine.
Old 06-07-2007, 09:01 AM   #11 (permalink)
Camryshowoff97
View Camryshowoff97's Photo Gallery
Yea I gotta agree with Dave's and Blue fusion about the whole flow part of this conversation. There are two beliefs on the path that current flows no one has been able to prove it yet. If it was - to +, lightning would only strike from the earth to the sky. It goes both ways. Im in school for Auto tech so its pretty fresh in my mind too lol, Definitely just replace your battery terminals though and it should be fine. If you cant figure out how to do it yourself, Take it to a shop. Should only charge you maybe 15 dollars to put them on for you.
Camryshowoff97 is offline   Reply With Quote
'85 rolla no start powerslide713 Older Generations (1969-1987) 10 04-08-2008 10:07 PM
1992 Cilica will not start Gil Celica Forum 6 05-19-2005 10:37 AM
extra battery 97avalonxls Audio, Video, and Security - Tech 9 09-20-2004 12:09 PM
Remote Start on Manual Transmission cars es250nut Audio, Video, and Security - Tech 2 09-12-2004 11:10 PM
