How Is This Terminal Supposed To Get Replaced? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2007, 06:24 PM   #1 (permalink)
View numberforty1's Photo Gallery
4th Generation How Is This Terminal Supposed To Get Replaced?
Ok, from everything I've read, replacing the positive battery terminal clamp is supposed to be an easy process of taking the battery cable out of one clamp and inserting it into the other. Well, if your car is like that, then its not like mine.
On my 98 Camry V6, you can't take the battery cable out of the clamp. It is crimped onto it, and the only thing you can do is to cut the cable. If you do that, however, you are screwed, because you are not left with enough cable to reach the battery anymore.
Instead, the battery wire comes from the starter, is attached to a piece of metal which is forever crimped to the wire, and the actual clamp is then bolted onto this piece of metal. The bolt is the one with the arrow pointing to it in the picture below. What it LOOKS like is that I SHOULD be able to buy a new clamp just like the one I have, unscrew the bolt holding the old clamp, and then just bolt the new one on - no messing with wires or using any cheapo universal clamps.
Can anyone confirm that this is right, and do I have to get the new clamp from Toyota? Firestone gave me some crappy universal clamp that only goes on if you insert the battery cable right into it, which is utterly useless.
Someone help!
Thanks
numberforty1 is offline   Reply With Quote
Old 06-06-2007, 06:39 PM   #2 (permalink)
View toyomoho's Photo Gallery
This may be an aftermarket cable. You should be able to find just the terminal end but you will need to call around. Or just buy a complete aftermarket cable complete with terminal.
Old 06-06-2007, 06:43 PM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
cut the cable, strip it
soldier a correctly sized extension
install new terminal.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 06-06-2007, 06:49 PM   #4 (permalink)
4th Generation I don't think so...
Well, if this is after-market, then Toyota installed an after-market cable, cause I bought this thing brand new. And there has got to be a way of doing this without an extension. I mean, who's got time to solder all day?
Doesn't anyone else have this kind of terminal?
Old 06-06-2007, 06:51 PM   #5 (permalink)
If Toyota OEM terminal, check the dealer for a replacement.
Old 06-06-2007, 07:08 PM   #6 (permalink)
Toysrme's Avatar
Cool
That's OEM. I told you how to fix it if you cut the wire.
Now with Turbo!
Old 06-06-2007, 07:15 PM   #7 (permalink)
View marc780's Photo Gallery
There are crimp-on cables with wiring attached for this, that you can buy. Image is from Kragen auto parts.
http://www.partsamerica.com/ProductD...egoryCode=3012
Old 06-06-2007, 07:28 PM   #8 (permalink)
The Greek....
GrkBallaG's Avatar
iTrader Score: 13 reviews
View GrkBallaG's Photo Gallery
Thats EXACTLY what you do. Why would you cut the cable and do all that unnecessary stuff on a terminal that is like that.
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 06-06-2007, 08:34 PM   #9 (permalink)
4th Generation K...
Well, thanks, but do you know where I can actually get the part to do it, other than Toyota?
Old 06-06-2007, 09:01 PM   #10 (permalink)
The Greek....
GrkBallaG's Avatar
We get them all the time from pepboys and napa
The SLAMry.....
Old 06-06-2007, 11:46 PM   #11 (permalink)
Local Rape Machine
View ekim55121's Photo Gallery
i did the otherway arround i bought all new cables and ran a seperate line to my starter from the front terminal from my optima, and avery thing else is running off of seperate cables going to the top post, best investment ive ever made i should take some pics for you. consider doing it
ekim55121 is offline   Reply With Quote
1989 Toyota Corolla SR5 Eyezell Archived Corolla threads 2 01-05-2012 07:19 PM
Front shocks have officially been replaced. pee_cup 89-95 Toyota Pickup/Hilux 4 11-22-2006 08:33 AM
Replaced Waterpump..NOW NOISE parimento1 3rd & 4th Generation (1992–1996 & 1997–2001) 4 09-24-2006 01:17 PM
What have you replaced on your AE86/AE92 since you got it? Fuel Injected Archived Corolla threads 15 09-05-2003 01:17 AM
