oil leaking and what is this?(pictures) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2007, 04:36 PM   #1 (permalink)
View gbaoyn's Photo Gallery
3rd Generation oil leaking and what is this?(pictures)
Hi, guys, I got oil leak on my 92 3VZ-FE with this part.but no manual says anything about it.Please let me know what it is called and if it is easy to DIY. It is located behind Exhaust Manifold,held by 3 bolts on engine. and look like it is one piece with oil filter base,because oil filter on it.(I don't know if any bolt on its left side,because i hv not removed the manifold .)than u for any info.
gbaoyn is offline   Reply With Quote
Old 06-07-2007, 08:28 PM   #2 (permalink)
I think i got it. it is called OIL FILTER BRACKET.Does anyone have experience with it? Thank you.
Old 06-07-2007, 08:54 PM   #3 (permalink)
Unco's Avatar
View Unco's Photo Gallery
download the manual for your engine. there's a section in the forums somewhere. the manual you want to download is the Lexus ES300 manual, as that will cover your engine. it is the oil filter bracket and by the look of things you just need to remove a few nuts and change the gasket/o-ring.
i would also suggest you look for oil leaks further up the engine as the whole side of your engine looks wet/dirty.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 06-18-2007, 09:34 PM   #4 (permalink)
Bouncing the rev limiter
92ES5sp's Avatar
View 92ES5sp's Photo Gallery
Thats a beautiful looking ziptie!!
92ES5sp is offline   Reply With Quote
Old 06-19-2007, 02:30 PM   #5 (permalink)
Gameroom cash: $133100
View profuse007's Photo Gallery
step 1- get degreaser and spray it down
step 2- check again next day for leak.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
