Squeaks on Drivers Side - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-08-2007, 01:03 AM   #1 (permalink)
Creeps228's Avatar
Gameroom cash: $274418
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
i search the forums but nothing matched to what im hearing from the car. Whenever im looking for parking or just cruising, i hear a squeaky noise form the wheels, i dont kow form which one it is, but sounds like its coming from the rear wheel. AS i move its squeaks and even after a highway run, couple 100 miles, it still squeaks? What could be wrong?
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 06-08-2007, 12:21 PM   #2 (permalink)
View keithy's Photo Gallery
does it squeak when you are moving? or when you come into contact with uneven surface? or when you apply your brakes? Need some more info about when the squeak occur.
keithy is offline   Reply With Quote
Old 06-08-2007, 12:43 PM   #3 (permalink)
View chullen's Photo Gallery
if it is when moving check you brakes if they are fine check the backing plate to see if it rubbing anything
1999 Camry V6 5 spd- Daily Driver
2006 Civic Si 192 whp- SOLD
1986 Corolla GTS 250 whp- SOLD
1996 Accord EX- SOLD
Production Team Leader at Mercedes Benz
chullen is offline   Reply With Quote
Old 06-08-2007, 01:49 PM   #4 (permalink)
View toyomoho's Photo Gallery
Is the noise in time with the wheel rotation?
Old 06-08-2007, 02:12 PM   #5 (permalink)
Creeps228's Avatar
it squeaks as im moving, through even and uneven roads, today i was paying attention to the speedometer and hearing the squeaks and i was going around 25mph and it was squeaking, will that help?
I dont hear the squeak when i apply the brakes just while driving slowly...and if it is the brakes what should i be looking for to replace/repair?
MR2: 7A-GE
Old 06-08-2007, 02:40 PM   #6 (permalink)
It might be a wheel bearing issue. I am not absolutely sure about this, but at least it is something worth looking into.
I suggest you jack the car up from the rear. Release the parking brake, and spin the wheel to see if you can repeat the sound which you mentioned.
I think my driver's side door sagged a bit Joe B 5th & 6th Generation (2002-2006 & 2007-2011) 28 06-05-2007 04:12 PM
07 Camry: Driver's side B-pillar rattle revisted proteus220 5th & 6th Generation (2002-2006 & 2007-2011) 7 06-02-2007 12:18 AM
drivers side windows cexsiman 1st Generation (1995-1999) 5 04-20-2007 02:35 PM
Water Leak - Driver's Side - 1991 PU Xtra Cab 2WD Toyota-fan 89-95 Toyota Pickup/Hilux 10 03-26-2007 01:34 PM
