Where is the engine coolant plug? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2007, 06:33 PM   #1 (permalink)
View decoder's Photo Gallery
'94 Camry - 4cyl
I looked everywhere in the book. I can't find it in the right rear of the engine block. Anybody have any pix of the engine area?
decoder is offline   Reply With Quote
Old 06-09-2007, 06:55 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
i always thought it was on the bottom of the radiator
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 06-09-2007, 07:54 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
It's on the back of the engine. You need to raise the front end and then slide underneath to get to it.
When you get to the back side, the intake side, look up and you should see something that looks like a water spigot pointing downwards and a bolt attached to it pointing towards the rear of the car.
You can use a piece of PVC hose to direct the flow so you don't make as much of a mess. The ID of the hose is 5/16" or 3/8", I don't remember which. The bolt is 10mm or 12mm IIRC.
2007 Camry 2.4L 5M
Old 06-10-2007, 07:21 PM   #4 (permalink)
View tarbasd's Photo Gallery
3rd Generation
14 mm on a '92 4-cylinder. I just changed my coolant.
A related question:
That engine block plug was a b*tch ro reach and loosen. You have to raise the car high, but still almost no space to turn the bolt. For the next time when I'll do coolant change, what if I only drain the radiator? I know I won't change all the coolant, but hey, when we change motor oil, tranny fluid, etc., frequently, some amount of old fluid will be left in the system. I drained slightly less than a gallon coolant from the radiator and about 2 quarts from the engine block. So if I only drain the radiator, I still change 2/3 of the fluid. I would do it every 18 months instead of every 24 months then. OK, I can't hose out the radiator, but it's not really necessary if it's not dirty, right?
tarbasd is offline   Reply With Quote
Old 06-10-2007, 08:25 PM   #5 (permalink)
View Yanpapa's Photo Gallery
I have a 97 Camry 4 cylinder, I see that there is a plug under a engine block but nothing like a "water spigot" like you described. Just an bolt. There is nothing that I can connect any tube at all. Does anyone know how to change it without making a mess?
Thanks.
Yanpapa is offline   Reply With Quote
Old 06-10-2007, 08:39 PM   #6 (permalink)
I don't know if you are looking at the right thing then. The drain for the coolant is on the back of the engine, not under it. The only plug under the engine that I can think of is the oil drain plug.
2007 Camry 2.4L 5M
Old 06-10-2007, 08:50 PM   #7 (permalink)
Actually it is on back of a engine. I have a Haynes manual and It is a coolant plug that I am refering to. Just does not have a any place or outlet to connect a tube.
Old 06-10-2007, 08:51 PM   #8 (permalink)
On the 98, probably same as 97, there is just a bolt screwed into the lower back of the block. ... Maybe you could get a 2" or so dia. pvc tube and hold it up to the coolant stream as you removed the bolt. .... also be sure and open the lower drain valve on the radiator. ... and remove the radiator cap.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 06-10-2007, 09:00 PM   #9 (permalink)
Wow, that's weird. Tarbasd's 1992 I4 and my 2000 I4 had the drain spigot but your 1997 and 1998 do not.
2007 Camry 2.4L 5M
Old 06-10-2007, 09:01 PM   #10 (permalink)
Thanks dc_98_cam, as long as I am not missing any parts on a drain bolt, I guess I have to drain it old fashion way.
Old 06-11-2007, 01:51 AM   #11 (permalink)
3rd Generation
I never said I had a drain spigot. It's just a 14mm bolt. For the question "how to remove it without making a mess", I don't know the answer. I *did* make a mess.
Now you see part of the reason why I want to avoid draining the engine block in the future.
Old 06-11-2007, 08:46 AM   #12 (permalink)
Doh!!
2007 Camry 2.4L 5M
Old 06-12-2007, 12:46 AM   #13 (permalink)
View marc780's Photo Gallery
I have a nissan pickup truck with engine drain plug some damn wheres, in 300,000 miles i ve never found it yet. It is not really worth it to me, to go through all that to get that plug out just to drain the block. Why not just flush the engine with clear water one more time instead when doing the change. If the thermostat opens the coolants circulates, after all.
Besides which, if you've ever changed the water pump, voila! Block drain included, no extra work!!!
I guess i'm lazy, but i just change my coolant every two years, flush it through the radiator and running the engine in between - and to hell with the block drain plug. (I've always used the green coolant, I wont use the red. Because I dont believe any coolant can go 5 years-and there have been tech bulletins that the chemicals in the red coolant can clog things up and even wreck your water pump.) Use distilled water too (i always forget this!)
This truck has still got its original radiator after 300k, so my cooling system treatments must be good enough.
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
Harsh 2-1 Downshift while in 'S' Mode Mistabullet 5th & 6th Generation (2002-2006 & 2007-2011) 20 03-19-2007 08:01 AM
Part IV; 20R ENGINE REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 6 10-05-2006 11:28 PM
Coolant woes; engine maybe history? JCxy 3rd & 4th Generation (1992–1996 & 1997–2001) 3 09-22-2006 07:58 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
