Replacing Disc Brake Pad - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2007, 06:42 PM   #1 (permalink)
View 94_v6_camry's Photo Gallery
Hi guys,
I really can't figure out what i have done wrong here....when installing in the new brake pad i can't get the caliper to slide it back in, did i get the wrong brake pad????
Yes i did depress the piston into the bore in the caliper with a large C-clamp to to make room for the new pads!!!
I don't know whether this is the right model for the rear or not "Toyota DB422BS".
Cheers
94_v6_camry is offline   Reply With Quote
Old 06-09-2007, 06:59 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
well its either that there the wrong size or u havnt compressed them enough. i had the same problem and it took some greasing up to get them on fallowed by brake cleaner to get rid of the lube. it worked but they were just tight, not the wrong ones. it my not have been right way however
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 06-09-2007, 08:24 PM   #3 (permalink)
No problem it's all good !!!
Old 06-12-2007, 12:57 AM   #4 (permalink)
View marc780's Photo Gallery
So you fixed? My guess is the replacement pads were just too thick. If they were non-OEM its entirely possible, they make these pads all over the world, usually Asia, and in everyplace from real factorys to mom and papasan working in their living room riveting linings on by hand. So its possible they just put on linings a few mm too thick?.
Brake pad Fittings taimurakhter Camry & Solara Lounge 1 02-10-2006 09:40 AM
Uneven brake pad wear CCCP Camry & Solara Lounge 6 10-29-2005 10:27 PM
about installing rear disc brake. yitping Archived Corolla threads 0 04-25-2004 07:49 AM
