Injen SRI Causing 'Check Eng." ?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2007, 09:32 PM   #1 (permalink)
xxswat718xx's Avatar
View xxswat718xx's Photo Gallery
Hey guys, I recently removed my Injen sri off my 97 I4 and I've had nothing but issues so far. I re-installed the stock airbox and now I have this check engine light that's been on for the past 2 days. On top of that, when I take off from a stop, the car "putters". There's a hesitation in the acceleration.
If you guys have any info on this matter, feel free to drop some knowledge on me. Thanks again, guys.
xxswat718xx is offline   Reply With Quote
Old 06-09-2007, 09:37 PM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
if you don't tell them what the code is, probably noone is going to answer you without guessing.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 06-09-2007, 11:39 PM   #3 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
disconnect the battery for about 15 mins and reconnect it. the car was used to a different amount of air (maybe) from the sri and when you put the stock back on, it probably isn't getting the same as it did before.
i think you just need to reset the ecu, really.
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 06-10-2007, 08:34 PM   #4 (permalink)
View OEMonkey's Photo Gallery
Check your work. You might have forgotten to re-connect a sensor or vac line. The IAT sensor plugs into the stock airbox. Listen to Toysrme and pull the code(s.) This will lead you to the circuit being affected.
OEMonkey is offline   Reply With Quote
Old 06-12-2007, 08:48 PM   #5 (permalink)
View toyo_tech02's Photo Gallery
did u use a k&n filter with that injen induction crap? if you did it probaly gummed up the maf.................... never ever use a K&N filter!!!!!!!!!!
toyo_tech02 is offline   Reply With Quote
Old 06-13-2007, 02:55 AM   #6 (permalink)
View imbest123's Photo Gallery
Bolt ons are so yesterday
imbest123 is offline   Reply With Quote
94 Camry Check Engine Light Code: 71 Check EGR Valve laksh99 3rd & 4th Generation (1992–1996 & 1997–2001) 15 10-29-2011 07:52 AM
Newbie here: Getting 95 camry today! Mjakaz95LE Introduce Yourself Here 24 04-21-2009 06:06 AM
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 11:52 AM
SRI - Check Engine Light? JohnCWms27 Camry & Solara Lounge 6 05-12-2005 10:00 PM
check engine light Injen? Azn Camry & Solara Lounge 4 10-03-2003 01:38 PM
