how big are these shock bolts? (axle install) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2007, 09:51 AM   #1 (permalink)
View dleccord's Photo Gallery
im trying to remove my driver's side shafts by taking out these 2 bolts which i hope will give the hub enough sway so i can knock the axle out. the arrows are pointing to them in the pic.
i believe there are nuts on both end and i was also wondering if they're the same size?
i didnt want to take out the castle-nut on the lower control arm as i can get my box-end wrench to fit in there and it almost strip the nut when i tried using the open end 19mm.
thanks.
dleccord is offline   Reply With Quote
Old 06-10-2007, 12:19 PM   #2 (permalink)
they're 22mm incase someone else were wondering
Old 06-10-2007, 12:24 PM   #3 (permalink)
The Greek....
GrkBallaG's Avatar
iTrader Score: 13 reviews
View GrkBallaG's Photo Gallery
The easiest way to get the axle out is to knock the lower control arm out. Its 3 17mm bolts and the control arm is out, and it gives you plenty of room to get the axle out. Taking out the strut bolts is unneccesary and if you dont get it exactly where it was it will throw off the alignment. Trust me, ive done hundreds of camry axles
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 06-10-2007, 02:13 PM   #4 (permalink)
fock. well rite now i got the shaft in, which was a bitch. i used a mallet and hit the other end. popped in but before that i was doing a little too much yanking in and out and now the inner joint is dislocated... (sighs) which the hub cannot move back into the shock assembly.
i gotta get a new shaft but taking this shaft in rite now out is a REAL bitch unlike before...
Old 06-10-2007, 08:40 PM   #5 (permalink)
i got the axle out by removing a metal cover right above where the shaft goes in the tranny and prying the axle out with two prybars, which did the trick.
im gonna return the other axle i bought from autozone and tell them its a defect. the last one i got from them earlier today has a pos head. the splines were mushroomed prerrt good: had to file them down.
those 3 bolts were tough ass hell. i had a deep socket socket on those and it wouldnt budge. looks like theyve been on there forever.
Toyota's new Tundra strikes fear among Big 3 toyotafanfan Toyota News 20 05-18-2007 07:52 AM
Best way to get these m***** F***** bolts out Jayota 89-95 Toyota Pickup/Hilux 7 02-27-2007 06:02 PM
Looking for rod bolts undertow29 89-95 Toyota Pickup/Hilux 20 02-13-2007 05:11 AM
New Rebuild with 350 miles, Retorque Head Bolts OK ?? PLEASE REPLY !!! reezytercel Tercel, Paseo, Starlet, and Sera Forum 1 01-29-2006 07:52 PM
bolts screws etc.... nodrogkam General Discussion 2 08-12-2005 12:42 PM
