worth taking the old one off first in order to compare to the replacement?
Not really, because the old one's stretched for sure, and so it's completely useless for sizing to a new belt. (A belt stretches within 20 minutes or less after you run it and its designed to do that anyway.) Your new replacement will most definitely be shorter than the old one. But you can take it along to check belt thickness and width if you wanted to.
A tip from my experience, don't use that belt dressing in a can-stuff except in a dire emergency! This crap has petroleum solvents and other junk and will eat your belt up for sure, after a week or two the belt softens and breaks and you still have to change it anyway, probably at night in a rainstorm or some other worst-possible time.
