Cooling system issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2007, 12:21 AM   #1 (permalink)
View 93ToyCorolla's Photo Gallery
USA Cooling system issue
I don't understand why I was low on coolant yet the overflow bottle was above the max. I thought when the radiator goes low it draws in the coolant from the bottle????????????
93ToyCorolla is offline   Reply With Quote
Old 06-11-2007, 03:32 AM   #2 (permalink)
Toyota Camry Vienta CSi
View Aussie_Camry's Photo Gallery
It does... but you need pressure in the system for it to suck the overflow coolant up!!! Id suggest changing your radiator cap (if you have the V6 I know this has two caps one for radiator one for water inlet, change both... its inexpensive)... this could be the source of pressure leakage meaning the system doesnt have enough to suck up coolant when it goes down.
Aussie_Camry is offline   Reply With Quote
Old 06-12-2007, 12:51 AM   #3 (permalink)
View marc780's Photo Gallery
How low is low? The system's designed to suck back in the coolant as you know, but this occurs through the heating and cooling of the engine when you shut it off - too many short trips in cold weather or something?
If you only added a few oz of coolant to the radiator it is probably normal - but what he said, change your radiator cap. Also blow water or something through your overflow tube to the bottle to check its not blocked or leaking.
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
Oil in cooling system rlrovol5 Pre-88 Toyota Pickup/Hilux 3 04-09-2007 07:48 PM
bleeding the cooling system. Alperovich 1st & 2nd Generation (1983–1986 & 1987-1991) 4 08-22-2006 12:29 PM
Idea for cooling system wildfire Camry & Solara Lounge 4 02-14-2005 07:13 PM
