Weird engine noise~! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2007, 06:48 PM   #1 (permalink)
Den
86 Celica Gt driver
View Den's Photo Gallery
3rd Generation Weird engine noise~!
Ok, I have replaced a JDM 3vzfe engine with my stock 3vzfe. Today, I just go to pick up the car and it has some weird noise when I give gas. Overall the engine seems a little bit more noisy than before the engine change. Can anyone tell me what is wrong?
thank YOU
1993 Camry LE "5 spd" with 410k + ... still going~!
1985 Celica GT
1986 Celica GT "GONE"
Den is offline   Reply With Quote
Old 06-11-2007, 08:10 PM   #2 (permalink)
View chullen's Photo Gallery
like the noise of the injectors or what maybe you have a vaccum leak somewhere
1999 Camry V6 5 spd- Daily Driver
2006 Civic Si 192 whp- SOLD
1986 Corolla GTS 250 whp- SOLD
1996 Accord EX- SOLD
Production Team Leader at Mercedes Benz
chullen is offline   Reply With Quote
Old 06-11-2007, 08:49 PM   #3 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
how is it performance wise? do you feel like there might be retarded timing or something like that?
this maybe a long shot but maybe the lack of an EGR makes it louder?
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 06-11-2007, 09:57 PM   #4 (permalink)
Den
86 Celica Gt driver
3rd Generation
First of all, thank you for the input
For the performance, compare to prior the engine change, it is pretty much the same. May be a little bit smoother. I know the noise is around the exhaust manifold. And the injectors are working fine.
1985 Celica GT
Old 06-11-2007, 11:27 PM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
may just be a leak...a sound clip would help if u could provide one. my camry makes LOTS of "weird" noises
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 06-12-2007, 05:13 PM   #6 (permalink)
Den
86 Celica Gt driver
3rd Generation
I checked again today, it will probably the leak from somewhere close to the flex pipe~
But now, I notice that there is some valve ticking noise. Is it normal? I asked the mechanic, he said b cox the engine that I changed was sitting on the ground for a while. He said that the noise will disappear after a week or so..
1985 Celica GT
Old 06-16-2007, 12:45 PM   #7 (permalink)
Menyahs's Avatar
View Menyahs's Photo Gallery
Flex pipes are notorious for leaking, if it's original or if you've grazed something while driving. Also tiny exhaust leaks near the motor can often sound like the ticking valve noise. Also i've noticed on both of the camry's that i've had (5sfe and 3vz-fe), as well as my father's highlander that you can hear the valves, unless it's very pronounced it could just be the way your engine sounds.
93 XLE Gold Edition 3VZ-FE
http://www.cardomain.com/id/menyahs
Menyahs is offline   Reply With Quote
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Harsh 2-1 Downshift while in 'S' Mode Mistabullet 5th & 6th Generation (2002-2006 & 2007-2011) 20 03-19-2007 08:01 AM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 12:05 AM
Best Way to attach a tool box to the plastic bed tacomacaver 2nd Generation (2005+) 9 02-21-2006 09:18 AM
weird noise coming from engine bay bobs Camry & Solara Lounge 1 01-15-2006 01:06 PM
