My drive (D) shift light had been burned out for some time and I finally decided to dig into the dash cluster and see what was inside.
After reading that the bulbs were only available from Toyota for silly amounts of money, I decided I'd try my hand at a permanent solution.
After checking with the LED calculator:
http://metku.net/index.html?sect=vie...calc/index_eng
I whipped up a close resistance and soldered together this:
http://www.gawd.mb.ca/camry/ledshift/
(I would've attached the pics but I don't seem to be able to attach things)
It worked out nicely, but the light is a little to one side, could use some aiming but since I used an amber LED (didn't have any whites in the basement) I put it in the reverse socket to it's not a big deal it's a bit off
I also moved the bulbs around while I was in there, put L1 and L2 into Drive and Park.
Sky
