Thoughts? (toga gasket set?) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2007, 03:04 PM   #1 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
I'm in the market at the moment for a complete gasket set. Some of you may remember my project with the Marko head, which is actually very quickly going to be taking shape.
The car currently had spun a bearing and is going to be getting a heart transplant in the form of a shortblock.
I've been trying to find reliable vendors of shortblocks but am having a bit of difficulty finding one. My current thoughts are to go with a city motor supply block, as their prices seem almost untouchable.
The head will be soon installed along with the rebuilt shortblock, the head's specs as they currently stand are complete flow-bench porting and polishing, milled to give a compression of 10-1, 4AGZE HKS valve springs, 2mm oversized valves, shimless buckets as well as a oregon cams cam regrind on 3SFE cam cores, which maintain the same base circle as the original 5SFE cams.
all the head work has been done from chrisK.
More onto the question at hand, I need to source a complete gasket set for the engine and have stumbled upon the Toga HP gasket set.
http://www.importperformanceparts.ne...ts-toyota.html
It's listed for a celica 5SFE, not camry but I'm going to make the assumption that there's no difference between the two. Also, are any of you familiar with the toga gaskets in terms of fits and so forth?
I'll try and keep this project more updated on the website as it unfolds. Thanks.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 06-18-2007, 03:32 PM   #2 (permalink)
Zzzz
bump* anyone?
-mark
5efe head gasket still leaking, I need advice fast !!! reezytercel Tercel, Paseo, Starlet, and Sera Forum 9 05-23-2010 11:26 PM
Oil Pan Gasket?? barthmonster Archived Corolla threads 4 12-30-2005 06:53 PM
Jest had a head gasket replaced MalooMAN Camry & Solara Lounge 0 06-08-2003 08:28 PM
is this gasket set on ebay a good deal? jr_certs Camry & Solara Lounge 1 10-10-2002 08:34 AM
