Iraggi Alt. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2007, 03:15 PM   #1 (permalink)
View Kalgatha's Photo Gallery
Iraggi Alt.
Hi guys, ok so I am planning on getting a HO Iraggi alternator along with (or shortly after) my sub and amp arrives. I just glanced at the alt in my car and it doesn't look to difficult to replace, but i must ask, is it? Is it simply plug and play? or is there more to the sceme? I have done little engine work but I'm fairly good at figureing things out. I want to know what all I would have to do to install the new Alternator. or if I should just take it to the local auto shop. Thanx!
Kalgatha is offline   Reply With Quote
Old 06-15-2007, 03:40 PM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
i thought you were going to iraq or something.
read the manual, then decide if it is up to your abilities.
alts are easy.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 06-15-2007, 03:40 PM   #3 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Its very easy. I did mine myself as well and I had no mechanical knowledge at all...
Its 2 main bolts and one nut for the wires.
Becuase it has a smaller pulley you need to make sure you loosen the adjuster bolt before you put the new one on, then pull the alt up and tighten the bolts. THEN use the adjuster to tighten the belt up but not too much.
good luck!
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Curry is offline   Reply With Quote
Old 06-15-2007, 03:48 PM   #4 (permalink)
Alright thanx guys!
HO alt 180-200amps oibone781 Car Parts for Sale 9 04-07-2007 06:14 PM
alt not charging,bad ground,can I jumper from batt to alt & run this way? petermiddleton 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-13-2006 10:03 PM
i was asked to be Canadian ALT (AE92) member in Japan TRDragoon Archived Corolla threads 19 07-28-2003 01:20 AM
