Power Window???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2007, 09:08 PM   #1 (permalink)
The Slowest of Slow
tsibole90's Avatar
View tsibole90's Photo Gallery
4th Generation Power Window????
Hey Tn, my passenger side window is stuck in the down position. I can move the other windows just not the front passenger. I don't know if the fuse is blown and I don't know if there is even a fuse just for that window. I don't think it could be the motor either. Is there another way to get the window up like manually... Please help.
97 Camry Le
tsibole90 is offline   Reply With Quote
Old 06-15-2007, 11:20 PM   #2 (permalink)
View toyomoho's Photo Gallery
Does this window operate with either passenger or drivers switch?
Old 06-16-2007, 12:10 AM   #3 (permalink)
The Slowest of Slow
tsibole90's Avatar
It doesn't operate with either.
Old 06-16-2007, 05:29 AM   #4 (permalink)
4th Gen Camry Owner
View kpszar's Photo Gallery
I would check the fuses first, and if the fuses are ok check the window motor. I think there is a way to check it. Take a battery and connect the wires, but im not sure.
kpszar is offline   Reply With Quote
Old 06-17-2007, 12:10 PM   #5 (permalink)
The Slowest of Slow
tsibole90's Avatar
Thanks... i hooked up the wires to another battery and the windowed rolled up.. now it works
1993 power window short on driver side fix? steve273 3rd & 4th Generation (1992–1996 & 1997–2001) 7 07-13-2007 08:53 PM
99 Camry Power Window Problems HELP HELP cato47 3rd & 4th Generation (1992–1996 & 1997–2001) 5 01-17-2007 02:57 PM
Power window woes loonmobile Camry & Solara Lounge 0 06-27-2006 05:47 PM
Power window adjustments...HELP kevintomb Camry & Solara Lounge 8 08-23-2005 05:55 AM
