Tranny Shifts REAL hard... help please? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-16-2007, 04:40 PM   #1 (permalink)
View 99Camry99's Photo Gallery
4th Generation Tranny Shifts REAL hard... help please?
1999 Camry LE, 5sfe, auto... had the tranny replaced in Dec. 2006 since the old one had a hole through the casing (yikes) anyways, its been shifting really rough in the past few months.
It is smooth when its cold when first started but gets worse as it warms up. It is rough through all gears, not just first. Not as bad between 3000-5000 rpms (highway merging, etc.) but worse between 1000-3000 rpms.
Two different mechanics said it might be a mount, also maybe the electronic shift points. Wrong transmission fluid was also brought up.
Do we have two seperate fluids in our tranny? Transmission fluid and final drive fluid? I've heard this final drive fluid get thrown around but have no idea what it is and I've done a bunch of searches for it too. Thanks folks.
99 Camry LE, Pioneer HU, Sirius, Boston Speakers, 2 12's, Tinted, CAI, K&N, Brembo Cross-Drilled, UD Pulley, Blue LED Underbody, Blue Wheel Well LED's, Blue, White, Amber LED Strobes, Corner Strobes, Autometer Gauges, Optima Yellow Top, “Big 3”, 1200w Inverter, Fog Machine & More... Ask
99Camry99 is offline   Reply With Quote
Old 06-16-2007, 05:19 PM   #2 (permalink)
View .Camryman97.'s Photo Gallery
does it do it with the a/c on cause mine shifts kinda rough when its on but when its off it shifts smooth
but if it does it either way then idk
97 Camry: 17" Enkei rims, lowered with Ground Control and tokico,
Alpine head, mids, and highs, rockford 4-channel, 12" P3 rockford,
MTX monoblock, TRD RSB, Clear Corners, 6K Mod Express HID kit
.Camryman97. is offline   Reply With Quote
Old 06-16-2007, 08:58 PM   #3 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
I doubt it would help, but there is a kick-down cable located underneath the throttle cable, which in turn controls how quickly the car shits. You can try moving the nuts more to the side (I forget which at the moment, lol).
geoff5093 is offline   Reply With Quote
Old 06-16-2007, 09:00 PM   #4 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
^ i believe its to the right
for some reason mine are all the way to the left, but i didnt do it ... and im the original owner ... so idk
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 06-16-2007, 09:21 PM   #5 (permalink)
I tryed the kick-down cable and it didn't really help, just made the rough shift slightly shorter cause it was shifting faster. It was still just as rough from when I adjusted it from the original setting/position.
Anyone ever hear of this final drive fluid tho?? Thanks
Old 06-16-2007, 11:05 PM   #6 (permalink)
Import Tuner
Spartan0536's Avatar
View Spartan0536's Photo Gallery
3rd Generation Final Drive Fluid
Let break down this "Final Drive Fluid" thing. First off its ok to ask questions like this, it is what we are here for. Final Drive Fluid = Blinker Fluid. If this doesnt click then let me explain: WHO EVER TOLD YOU THAT LOAD OF CRAP PROBABLY DOESNT KNOW A CAMSHAFT FROM A DRIVESHAFT. Tranny Fluid is the only fluid in your transmission (I Hope) :P.
Spartan0536 is offline   Reply With Quote
Old 06-17-2007, 03:15 PM   #7 (permalink)
Thanks for the help Spartan but there is no need for the sarcastic crap. Apparently I'm not as smart as you but I'm only telling you what a mechanic told me and I never heard of it before so that's why I asked.
Old 06-17-2007, 03:20 PM   #8 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $906827
iTrader Score: 59 reviews
Ya get sarcastism on TN sometimes...believe I know! But most of the members here are really GOOD PEOPLE, don't let it bother ya!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 06-17-2007, 05:13 PM   #9 (permalink)
View marc780's Photo Gallery
I think its possible that you could have gotten a rebuilt transmission that requires Toyota TIV fluid. But since you paid them to replace your transmission and now it doesnt work right, the damn shop should really fix the problem after all. What kind of idiots would "fix" a trans and then give it back to you shifting like that?
However - I dont know what trans model number goes to what year etc. But unless you are certain they just rebuilt your old one, its very likely the shop just grabbed whatever one off the shelf they had rebuilt that they thought would fit and stuck it in there! So in other words maybe its possible you got a trans for a newer camry installed in your car and this trans requires TIV fluid? If it requires TIV and Dexron is used instead, Toyota says it can cause bad shifting. A fluid flush is worth a try before you tear into it again - TIV fluid is a dealer only and it costs about $5 a qt, unfortunately - i'd use a 2 or 3 gallons of it and flush out the old stuff.
as for your question about whether the final drive fluid is seperate from the trans fluid or not - depends on the year and engine etc. For the best answer look here, factory manuals with maintenance info:
http://www.camrymanuals.com/
Old 06-17-2007, 06:30 PM   #10 (permalink)
Thanks for all the help guys. I tried the kick-down cable but this time I loosened the shit out of it. It helped 100%. So I tightened it back up to take the slack out of it but not so much to the point where it made the shifts rough again. I guess we'll just see how it goes.
I'm gonna leave it that way for the rest of the week. Then we'll see how it handles after a few daily commutes.
Old 08-06-2007, 11:37 AM   #11 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Any update on this 99Camry99? Id like to know how your car was after the week.
THanks!
xtremeskier97 is offline   Reply With Quote
Old 08-06-2007, 12:14 PM   #12 (permalink)
audionut71's Avatar
View audionut71's Photo Gallery
4th Generation
At the risk of being flamed, is it possible the mechanic meant the differential instead of the "final Drive". There is a seperate drain for that, right?
'99Camry LE I4
Eibach Springs, KYB Struts, Alpine deck, Memphis System, Crime Guard remote start, now sporting Strut brace & Whitline RSB thanks to Team Hamster and Ohio Force!
audionut71 is offline   Reply With Quote
Old 08-06-2007, 12:28 PM   #13 (permalink)
View steppinthrax's Photo Gallery
What the hell is a kick down cable. I have a 99 Camry with an auto tranny. I though the transmission valve body controlled the shifting. That can't be controlled externally right????
steppinthrax is offline   Reply With Quote
Old 08-06-2007, 12:30 PM   #14 (permalink)
It's a FWD transmission the Final drive gear and differential are housed in the same unit. There is not seperate fluid. The transmission is so small.
Old 08-06-2007, 12:39 PM   #15 (permalink)
Venom_5's Avatar
the kick-down cable is right below the throttle cable [on the same little pulley-wheel-thingy] .... and yes, it allows you to adjust basically how late the tranny will shift ... i think it allows the tranny to take more pressure before it decides to shift up, making it slightly more sporty [or, as sporty as a camry can get]
!!new 5SFE tranny needed!!! streetnasty Celica Forum 3 09-03-2006 08:46 PM
Smooth Shifts sameer2601 Camry & Solara Lounge 22 03-22-2006 11:05 PM
How hard to pull tranny in MR2? mr2naturbo MR2 Forum 2 07-30-2005 07:15 PM
Yet another Gen 2 Tranny problem spills1969 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-24-2003 02:15 AM
