1992 Camry LE i4 ~230k (km's) oil pressure light goes on when first starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-16-2007, 11:06 PM   #1 (permalink)
View bullycanadian's Photo Gallery
Is it normal for the oil pressure light to go on red when the car is first started after being turned on after resting for a long period of time (ie I start the car in the morning after its sitting all night and the oil pressure light is on for the first 3 - 4 seconds) and yes I did check the oil its full.
Is it normal? My buddy has a '92 v6 (but newer engine with only 70k kms on it) and the oil pressure light doesnt go off on his.
bullycanadian is offline   Reply With Quote
Old 07-07-2007, 11:53 PM   #2 (permalink)
Hey never got a reply,is this normal????
Old 07-08-2007, 06:52 AM   #3 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
No, it is not normal. What weight oil are you using? It is also possible that there is a low pressure problem. More likely, the pressure sending unit is failing. Also, some brands of oil filters don't prevent drain back. What filter brand are you using?
DFBonnett is offline   Reply With Quote
Old 07-08-2007, 09:05 AM   #4 (permalink)
I'm using 5w30 Dino oil. Originally it was doing it with the filter that came with the car, i then had the oil changed and the new filter on it is a pennzoil filter. Is there anyway I can tell is the pressure sending unit is failing????
Old 07-08-2007, 11:41 AM   #5 (permalink)
Gameroom cash: $303055
Take it to a shop and ask them to remove the oil pressure sending unit and temporarily install an actual gage in it's place. They will then take pressure readings and compare your oil pressure to the engine's specifications. If the pressure is normal, they can order and put in a new sending unit, instead of replacing the old (obviously defective) unit. This would cost you about 1 hour of labor and about $25 for the new (aftermarket) sending unit. If the oil pressure is actually low, the tech will have to do further testing to determine if the problem is a weak oil pump (hope for this) or worn engine bearings.
Mike
Old 07-08-2007, 08:47 PM   #6 (permalink)
Mike
Also only does it when the engine is cold, does that make a difference other than taking the car there and letting it sit for a few hours. Also if its worn engine bearings, what other symptons would I have??
Camry Oil Level low 07 LE I4 trdsupragt 5th & 6th Generation (2002-2006 & 2007-2011) 9 02-16-2007 12:36 AM
oil change ,99 camry le bronxstreets 3rd & 4th Generation (1992–1996 & 1997–2001) 12 01-29-2007 02:21 PM
96 Camry LE I4 2.2L willchugs400 Vehicles 4 03-25-2006 02:24 AM
2003 Camry LE V6 3.0 Oil Change SuperGT 5th & 6th Generation (2002-2006 & 2007-2011) 15 03-14-2006 08:07 AM
Flickering Oil Pressure Light jhale1 Camry & Solara Lounge 0 02-17-2003 04:22 AM
