Cooling fans always on? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-16-2007, 11:55 PM   #1 (permalink)
nuchieboy's Avatar
Gameroom cash: $203299
View nuchieboy's Photo Gallery
4th Generation Cooling fans always on?
for some reason even when my car is cold the cooling fans turn on and dont seem to shut off...what could possibly be the problem?
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 06-17-2007, 01:06 AM   #2 (permalink)
View camryvibe's Photo Gallery
I have the same issue with my '87 Nova/Corolla I'm pretty sure the problem is a defective temperature sensor/relay that controls the fan operation based on the radiator temperature. But the sensor/relay isn't very cheap and the extra fan operation doesn't seem to noticeably affect mileage, engine warmup, or any other function. So I haven't bothered to replace it yet.
camryvibe is offline   Reply With Quote
Old 06-17-2007, 09:12 AM   #3 (permalink)
nuchieboy's Avatar
4th Generation
yea but i want to get it fixed....any other ideas?
Old 06-17-2007, 10:01 AM   #4 (permalink)
Check the temperature sensor that's plugged into the radiator. It should be a closed circuit (almost zero resistance) when the radiator is cold and an open circuit when it's hot. If that's the problem then get a new one and replace it. Otherwise check the wiring that goes to the sensor. Any bad connection or break in the wire will make the fans run all the time.
Old 06-17-2007, 10:11 AM   #5 (permalink)
nuchieboy's Avatar
4th Generation
theres 2 sensors on one side and one on the other so i guess i have to check all of them? how much would a normal shop charge me to fix this? and also how much is the part? thanks
Cooling fans keep running.. WTF! newbie212 Archived Corolla threads 8 12-20-2006 08:48 PM
Cooling fans not working on my ’86 Camry atikovi 1st & 2nd Generation (1983–1986 & 1987-1991) 4 11-23-2006 10:09 AM
No Cooling Fans (!) arjay8 1st & 2nd Generation (1983–1986 & 1987-1991) 10 10-12-2006 05:10 PM
Problem With Cooling Fans, please have a look: Dr Tweak Hardcore Tech and Competition 2 02-21-2005 01:22 AM
cooling fans |PuNiSh3R| Archived Corolla threads 0 02-11-2004 10:21 PM
