Coolant and Transmission Drain/Refill Assistance - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2007, 06:24 PM   #1 (permalink)
View money3's Photo Gallery
Canada Coolant and Transmission Drain/Refill Assistance
Hello all.
I am getting all the items ready to do a DIY coolant and transmission drain and refill. I am a semi-noob when it comes to this however (with the exception of some work on a 99 Caravan). I have searched through all the previous posts for some background info, as well as the ********** guides but still have a few questions.
Important info:
1995 Camry 1MZ-FE V6 ~280000km
Fluids:
Some generic premixed coolant
Motomaster ATF fluid (label indicates Dexron 2 and 3 compliant)
Problem areas:
-Having some difficulty locating the rad drain **** (not planning on draining the engine block as it is too much hassle)
-The Toyota manuals indicate a 10mm hexagon wrench as needed to open the drain but the 10mm socket I have does not fit. Is there a special tool or different name for this tool?
Essentially, I wanted to know if my choices of fluids are ok and if somebody could guide me in the problem areas?
Thank you
money3 is offline   Reply With Quote
Old 06-17-2007, 10:58 PM   #2 (permalink)
ycartf's Avatar
View ycartf's Photo Gallery
The radiator drain is located at the bottom inner side somewhere (Gen4 on the driver's side of center). If you cannot find it you can disconnect the lower radiator hose. If you want to drain all the coolant do this - A buddy and I (on his wife's 2001 Gen4) took the thermostat housing off and opened the heater control to all-the-way-hot (car cold and not running), disconnected the radiator end of the top hose and duct-taped a blower to it - then blew all the old coolant out that was trapped in places I could not drain even after draining the block and changing the water pump. Looking back we would have shrouded it somehow to maybe keep it from blowing all over everything but it worked like a charm.
The transmission drain plug is a 10mm Allen - the one I use is just a 3/8" drive socket that is 10mm Allen.
Tracy Faulkner
ycartf is offline   Reply With Quote
Old 06-18-2007, 02:34 PM   #3 (permalink)
View toyomoho's Photo Gallery
Suggest using a long life coolant that is silicate and borate free. Prestone and Havoline make such fluids, mix with distilled water.
For ATF use any name brand Dexron III.
Old 06-18-2007, 06:59 PM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Motor master ATF is fine, Stick to Toyota red and distilled water for coolant.
At this age (milage) you should consider changing the hoses - rad , bypass (under intake plenum) and heater.
And changing thermostat if that has not been done yet.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
Price for Coolant and Transmission flush and fill? persianKID Camry & Solara Lounge 4 04-28-2004 10:57 PM
