help!!! maf sensor problem??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2007, 08:14 AM   #1 (permalink)
View superman_143's Photo Gallery
ok we decided to put on a intake adapter with a filter and everything went good until we started the car . the car was running erratic in the beginning. it started and ran for a little bit then died out. we kept starting it and later on down the line it wouldn't want to start for us. we put everything back to stock then it did the same thing. im thinking its the maf sensor that went bad on us. we play with the connector going to the sensor while trying to start the car and it starts then we stop playing with it then it dies. so all in all thats the only thing we touched today so im thinking its that . how could it go bad just like that? did we screw something up? all suggestions is appreciated. thanks toyota gurus .
superman_143 is offline   Reply With Quote
Old 06-19-2007, 09:18 AM   #2 (permalink)
View rotarydave's Photo Gallery
I've been having the same problem lately. Occasionally, I would mess with the connector enough, the MAF would work properly. Now, I'm ordering a new electrical connector to fix the problem. If your car is throwing a P0100 code and not a P0101 then the connector or wiring is usually at fault.
rotarydave is offline   Reply With Quote
Old 06-19-2007, 07:18 PM   #3 (permalink)
well no signs of check engine light came on yet . so its a long shot but i hope it is that. should i order the connector or the sensor itself? thanks
Old 06-19-2007, 07:26 PM   #4 (permalink)
View toyomoho's Photo Gallery
Before changing parts download the service manual at the link below, it has troubleshooting and testing methods.
Does the engine start and run when the gas pedal is pushed down. Might also check the IAC valve. Codes could still be present without a check engine light.
http://oregonstate.edu/~tongt/camry
Old 06-19-2007, 07:43 PM   #5 (permalink)
i just called my friend and he said yeah it started today but it died out shortly after that. should i just jump the connector and check anyway for a code? thanks
Old 06-19-2007, 07:53 PM   #6 (permalink)
Gameroom cash: $147537
You may have missed a hose and created vaccum leak after the sensor. There should be no hole on the intake after the sensor.
Old 06-20-2007, 12:37 AM   #7 (permalink)
hey pineapple i think your thinking of something else. im refering to this http://cgi.ebay.com/ebaymotors/86-94...28631313QQrdZ1
Group Buy for PSC1 (15 more HP) Pb 2nd Generation (2005+) 82 12-24-2008 10:33 PM
URD Maf calibrator installed. tacogrande 2nd Generation (2005+) 122 11-21-2007 03:23 PM
Cleaned MAF sensor, Check engine light on cheesycoolguy 1st Generation (1995.5–2004) 13 02-26-2007 04:16 PM
AFM OR MAF how to swap? canadianae92 Archived Corolla threads 7 11-11-2005 01:26 AM
MAF problems. need much help 93cam Camry & Solara Lounge 6 05-06-2005 10:08 PM
