Items to replace when replacing Suspension - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2007, 08:31 AM   #1 (permalink)
View kaizoo's Photo Gallery
I plan on having my 1998 Camry 2.2L front and rear struts replaced. after reading a ton of stuff on this site, I feel that when replacing struts the following items should also be replaced:
4 new KYB Struts
Left Front Strut Mount
Right front Strut Mount
Left Rear Strut Mount
Right Rear Strut Mount
Left and Right Front lower Insulator
Left and Right Lower Front Insulator
Left and Right Rear Lower Insulator
Left and Right Rear Upper Insulator
Please let me know if there are other items you guys thing that should also be replaced with this work. Your input is greatly appreciated.
Thanks!
kaizoo is offline   Reply With Quote
Old 06-19-2007, 08:51 AM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
if you have the money, i would strongly suggest replacing the springs too [if your struts are shot, chances are the springs could use a makeover too]
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 06-19-2007, 11:32 AM   #3 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i am not sure if the boots are included in the strut mount, if not, take a look at the old one see if it is still in good condition or torn.
bronzemaxell is offline   Reply With Quote
Old 06-19-2007, 11:39 AM   #4 (permalink)
Venom_5's Avatar
the boots arent included, i forgot about that one ... if your old boots are torn, get some KYB boots ... theyre only like $14 a piece
Old 06-19-2007, 11:42 AM   #5 (permalink)
View Kiasis's Photo Gallery
Just FYI - I told my mechanic to replace anything and everything that looked worn when he did my new springs/struts. He didn't touch the mounts, bearings, isolators, boots, etc. He said they were all completely fine and couldn't justify charging me for parts that weren't the least bit worn out. I expected all new parts, almost begged him to reconsider, but he wouldn't do it. Either I've got a great mechanic or a stupid one (I choose to believe the former).
Kiasis is offline   Reply With Quote
Old 06-19-2007, 11:53 AM   #6 (permalink)
Venom_5's Avatar
look at the parts yourself ... i can see that my boots are clearly torn, it doesnt take a mechanic to know that one
the mounts will pop/click if theyre getting old ... idk about bearings or insulators
Old 06-19-2007, 10:13 PM   #7 (permalink)
Member
View triggerhappy007's Photo Gallery
The rear upper insulators comes with the rear strut mounts (at least the KYB ones). Are you sure you need to replace everything? It's going to be pricey.
triggerhappy007 is offline   Reply With Quote
Old 06-20-2007, 08:20 AM   #8 (permalink)
I am sure if I should replace everything. But reading the forum people suggest that you should change the Strut mounts, boots and insulators as these item do wear off after 8 or 9 years of use. Any suggestions would be appreciated.
Old 06-20-2007, 09:33 AM   #9 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
hello mates:
where can i find on the internet diagrams of the 2005 camry front suspension and front shocks/struts layout.
thanks brothers.
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Suspension system - Need Help/Advice! bavula 3rd & 4th Generation (1992–1996 & 1997–2001) 15 04-18-2007 11:04 PM
complete suspension replacement on gen4 (it's a boat!) thenoeltyler 3rd & 4th Generation (1992–1996 & 1997–2001) 6 06-30-2006 04:03 PM
need to replace the suspension on my camry....can anyone suggest a good set of shocks xxpanipuri Camry & Solara Lounge 8 02-10-2004 06:55 PM
