Need keyless remote for 96 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2007, 08:12 AM   #1 (permalink)
View projectpete19's Photo Gallery
Hello,
I just bought a 96 Camry with a 4 banger. It did not come with any of the keyless remotes, I found this one on ebay http://cgi.ebay.com/ebaymotors/KEYLE...31474533QQrdZ1 has anyone else used these off ebay? Do they work?
Also, are there any instructions on how to reprogram them? I saw there are instructions for Gen4 but not ours on this site.
Also, do we need the grey remotes or the black ones? Is there a number I should be looking for so I get the right remote?
projectpete19 is offline   Reply With Quote
Old 06-20-2007, 09:11 AM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
dont get a cheapo eBay one that claims its specific to your car [when its really not] ...
have one installed at a local shop
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 06-20-2007, 09:31 AM   #3 (permalink)
its not a cheapo ebay remote its a factory toyota remote. why would i install another aftermarket keyless entry when there is already one in the car.
Old 06-20-2007, 12:05 PM   #4 (permalink)
View keithy's Photo Gallery
that remote is for the rs3000 system. Yes, it is true that you can buy that and reprogramm it to your car. But I have a few tips and advice for you before you do.
The rs3000 comes with TWO different remotes that looks the same. Namely the black ones and grey ones. They both have the same fcc id #, which you think might be interchangeable. But unfortunately they are not interchangeable. Yes, I have tried them out.
To know which one works for you car, you have to locate your ecu unit and look at the color of your ecu unit. Then the remote should be of the same color.
you can find more information in the sticky section where I have summarized the procedure to program your remote. Good luck!
keithy is offline   Reply With Quote
Old 06-20-2007, 03:12 PM   #5 (permalink)
View camree99's Photo Gallery
Got a question. Is having a keyless entry remote activates glass breakage sensor? and does this also activates the VIP alarm system? got recently vandalized and burglarized and deciding whether i should buy the keyless entry remote or an aftermarket alarm system.
camree99 is offline   Reply With Quote
Old 06-20-2007, 04:58 PM   #6 (permalink)
answer to your question
1. NO. Having the keyless entry does not "automatically" activates the GBS or your alarm. You have to have the rs3000 alarm to have them work together. If you only have the keyless entry feature, then there will not be any GBS or alarm.
2. Aftermarket alarm will give you more features. Some are even better than the toyota alarms, just my personal opinion.
Old 06-22-2007, 04:42 PM   #7 (permalink)
Thanks keithy! anyway, i remember finding a glass breakage sensor while i was looking for the ecu ( the size of a matchbox with label on it), but im not sure whether i have the RS3000 alarm. im wondering how this glass breakage is activated.
Old 06-23-2007, 09:09 PM   #8 (permalink)
if you have the rs3000, and you did not disable the alarm, the GBS should also be enabled. You can adjust the sensitivity of the GBS though. As far as I know, the GBS is part of the alarm system and you cnanot just disable the GBS alone.
2004 CAMRY LE keyless remote programming help! ih8bnb8 5th & 6th Generation (2002-2006 & 2007-2011) 9 12-15-2008 01:29 PM
2000 Camry w/ keyless remote issue ctks 3rd & 4th Generation (1992–1996 & 1997–2001) 4 03-22-2007 04:26 PM
1994 camry keyless entry remote programming instructions camry528 3rd & 4th Generation (1992–1996 & 1997–2001) 1 06-20-2005 10:12 PM
2000 Camry Remote Keyless Install Axeman71 3rd & 4th Generation (1992–1996 & 1997–2001) 3 04-28-2005 08:45 PM
