I think the Idle Speed Control Motor and Air Speed Control Motor are the same part. It should be a stepper motor controlling idle speed. If it needs to be replaced you could remove it and take it to Kragen for comparison. The distributor cap oil plug is probably the distributor shaft o-ring. The leak could be from that o-ring or from the valve cover in that area where RTV sealant is supposed to be applied at the sharp corners of the valve cover gasket.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
