Throtle sticks - high RPMs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2007, 07:41 PM   #1 (permalink)
View Jerryb's Photo Gallery
The throtle on my 92 Camry V6 sticks when I step on the gas. If I go under the hood and race the throtle with my hand, it returns to 900 rpm, but when I step on the gas pedal, it won't return to low rpms. It just keeps reving at 3000rpms. I sprayed the throtle cable and linkage with WD 40 but no change. Where could it be sticking and why?
Jerry
Jerryb is offline   Reply With Quote
Old 06-23-2007, 07:50 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Try cleaning the throttle body and butter fly valve with TB cleaner. Wipe it down and scrub it with an old tooth brush.
Lubricating the throttle cable doesn't work very well and it'll probably get worse since you sprayed WD-40 all over it.
2007 Camry 2.4L 5M
Old 06-24-2007, 08:57 AM   #3 (permalink)
Gameroom cash: $303055
I have to agree with touringcamry on this. Your symptoms sound like the classic case of a dirty throttle body. If you do not know how to clean it do a search on this forum for "throttle body cleaning". It has been covered numerous times and there are some threads with pictures on how to do it.
Mike
Old 06-24-2007, 11:43 AM   #4 (permalink)
Thanks for your suggestions. I'll try your suggestions about the TB. If it is the the throttle body, why doesn't it stick when I pull the cable from under the hood?
Jerry
Old 06-24-2007, 12:19 PM   #5 (permalink)
No idea...check out this thread
http://www.toyotanation.com/forum/t196108.html
2007 Camry 2.4L 5M
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
URGENT! How high should camry Clutch engage? blueapple Camry & Solara Lounge 11 03-23-2009 09:44 PM
2000 Sle High Pitch Squeal mh808 Solara 10 07-10-2007 02:35 PM
high reving engines rice Archived Corolla threads 13 12-08-2005 05:39 PM
Even a year out of high school, I am still bitter... kenratboy Off Topic 17 02-16-2004 02:56 PM
